Ignition upgrade
Posted: Sun Aug 28, 2011 10:43 pm
by gumper
I have looked at the past posts on this subject but didn't find what I am looking for. The pages at the Pertronix site didn't answer everything either.
My points are worn out I was thinking of going to a pertronix Ignition Conversion . I was looking at there site and there is two choices #1 Flamethrower and #2 FlamethrowerII . Which one would anyone of you recommend?
If I went with the first one part # 1581 they have a matching coil which is either 1.5 ohms or 3 ohms. If I use one of these do I remove the ballast resistor from the circuit? I think I should get the 1.5ohm coil. Am I wrong.
Posted: Mon Aug 29, 2011 6:35 am
If the company that makes can't give you answer then I would deal with someone else . Support is everything . or you could just replace the points
Posted: Mon Aug 29, 2011 9:43 am
by gumper
To be fair to pertronix. I did not contact them directly. I only read what was on there support pages. I sent them an email today and got back a reply saying they will have an answer within 48 hours.
Posted: Mon Aug 29, 2011 12:48 pm
by vabeach1234
I tried two on my 318 and they both wouldn't advance so my max rpm was about 3000. Took it off and ran like it should up to 4000. I personally don't have faith in them for my application and would go with a whole new Mallory Distributer before trying another Pertronix kit.
Posted: Mon Aug 29, 2011 7:55 pm
by wowzer52
The points system in my boat have been working for 36 years.
Posted: Mon Aug 29, 2011 8:15 pm
by Paul
I've been running a Seirra Ignitor kit in my Mallory points type distributor for 6 years now with no problems.
see attached
http://marineengineparts.com
Posted: Tue Aug 30, 2011 6:45 pm
by Big D
Typically these units require a full 12 volts to operate but you should confirm with the manufacturer. If you use your current coil that requires a ballast resister, you could connect the unit to the supply side of the resistor which will be 12 volts rather than the load side going to the coil. I've been running first generation units on my 440s for about 8 or 9 years now.
Posted: Tue Aug 30, 2011 7:44 pm
by gumper
I know the points have system has lasted for over 41 years on the boat. With the price of fuel and the fact that I need to replace the wiring and coils due to normal maintenance. The difference in cost is very little . I am going to try it and keep the old parts for emergency backup.
I was talking to the support department and they recommend using a 1.5 ohm internal resistor coil and removing the ballast resistor.
I am curious those of you who have installed these units. Did you notice any differences? ie Power or fuel efficiency
Posted: Thu Sep 01, 2011 6:41 am
by g36
i installed these this year on both my 318 engines. same distributor either engine pulled the old installed the new. easypeasy. ballast resistor depends on the coil used
http://www.summitracing.com/parts/MAA-YLM579AV/
Posted: Thu Sep 01, 2011 5:53 pm
by Big D
There may be a theoretical or slight measurable difference in performance but for all intensive purposes, there is no noticeable difference that I can see, though the manufacturers of these claim otherwise. What I did notice right away was that the engines started up much faster, easier.
Posted: Tue Sep 06, 2011 8:32 pm
by gumper
I went ahead and installed the electronic ignition on both engines this weekend. After talking to someone from Pertronix I installed two new coils as well and removed the ballast resistor from the circuit. My distributors were 42 years old and worn. Prior to the new ignition my timing marks would jump around when checking the timing. The timing marks are rock steady now. I have noticed a large difference in starting the engine and throttle response is much better.
So far I am very happy with the change over. I will be heading out next week for a couple of hundred km trip. It will be interesting to see any other improvements.
