Found a great 318 complete but a question
Posted: Sun Sep 04, 2011 5:26 pm
by bkwesq
The new engine is reverse rotattion is that a problem for my F25? single engine obviously - what do y'all think?
Posted: Sun Sep 04, 2011 6:59 pm
by Scorpyon
As long as your prop matchs your rotation u should be ok
Posted: Sun Sep 04, 2011 7:47 pm
by bkwesq
Ok thanks that's all I wanted to know!
Posted: Sun Sep 04, 2011 7:57 pm
Are you using the old trans ? If so you will need to rotate the pump on the front of the trans .
Posted: Sun Sep 04, 2011 8:02 pm
by bkwesq
Yes sir - I planned on using it. I will look for the pump not sure what that is but I will figure it out
Posted: Sun Sep 04, 2011 8:05 pm
Look at the top of the forums you will see some manuals .
Posted: Mon Sep 12, 2011 7:07 pm
by larryeddington
in a conversation today with beacon bob the topic of single screw engine rotation. According to bob virtually all single screw applications use reversie rotation engines. According to him either directon will propel but for an engineering reason reverse gives better performance.
Go figure, BTW he said I could quote him.
Posted: Mon Sep 12, 2011 7:10 pm
by bkwesq
I have to get him down here - he is only 30mins away
Posted: Mon Sep 12, 2011 8:14 pm
by myakka
My understanding is, it was economy of scale that lead most boat builders to buy reverse rotation engines for the single screw models. I guess I could be wrong.
Posted: Mon Sep 12, 2011 9:30 pm
I have worked on a lot of boats a normal rotation is the norm on single screw boats . and reverse rotation engines cost more then standard
Posted: Mon Sep 12, 2011 10:56 pm
by mr elevman
its my understanding rh rot is standerd rot on ford and chevy but lh rot is std on a chrysler and rh is reverse
