1976 Trojan F30?
Posted: Fri Sep 30, 2011 6:27 pm
by SweetOlive
We just purchased her a couple months ago, I know from the title she is a 30' Trojan 1976, but I was wondering if anyone could identify the model for me ?? :) We have just started fixing her up & I would love any feedback I can get :)
[img][img]http://farm7.static.flickr.com/6151/619 ... 4082d2.jpg[/img]
DSCF0003 by BrokenSpecialMuse, on Flickr[/img]
[img][img]http://farm7.static.flickr.com/6163/619 ... d8167b.jpg[/img]
DSCF0567 by BrokenSpecialMuse, on Flickr[/img]
[img][img]http://farm7.static.flickr.com/6170/619 ... f28033.jpg[/img]
IMAG1920 by BrokenSpecialMuse, on Flickr[/img]
Posted: Fri Sep 30, 2011 6:53 pm
F30 express I belive what a the last 3 numbers in the hull ID ?
F 30 SPORT CRUISER MODEL 300, 301
F 30 EXPRESS MODEL 302, 303
F 30 SPORTS CRUISER SINGLE SCREW MODEL 305, 307
F 30 EXPRESS TWIN SCREW MODEL 304, 306
F 30 FLYBRIDGE SEDAN MODEL 308
Posted: Fri Sep 30, 2011 8:08 pm
by SweetOlive
I will have to check tomorrow, unless the hull id is the same as the identification #? That ends 276
Thanks for responding :)
I had seen some pics of an express but it did not have the front windows so I was not sure. But they may have been added later.
Posted: Fri Sep 30, 2011 9:04 pm
It Is the same number But there will be 3 more numbers on the hull
(-XXX) that should be your model number The last 3 may not be on your paper work look at the hull
example my F36 hull id is TRJ0xxxxxx77-460 the 460 for F36 convertible . BTW the 77 is the year built . I know this is the way it it is on 1977 and newer .on some early 70s boats The 3 numbers that follow TRJ maybe the model number ( not sure but read a post on this )
Posted: Sat Oct 01, 2011 3:07 am
by rossjo
http://www.trojanboats.net/wforum/viewtopic.php?t=2941
Hull number - TRJ number
The TRJ (Coast Guard certification number) is found on the starboard side of the transom just above the swim deck if she has a one. This would be true of all fiberglass Trojan hulls 1970 - 1992. TRJ stands for TROJAN and this is the Coast Guard certification number and the one that is often found on your registration.
The Hull number or as is some time referred to the (working hull number) is found on a tag made of aluminum by the AC DC panel, inside the door of the AC DC panel or below the AC DC panel. On some smaller Trojan under 30 ft it is often found on the back of the head door or a closet door.
On the F 30 Clean Machine it is on the inside of the closet door starboard side forward.
This Trojan tag has the engine ID number (s), inspector number and the Hull number which is three numbers followed by four. This number is its finger print of your Trojan and is the easiest to work with or decode.
The first three numbers are the model of you Trojan 321 is a F 32 Sedan, 251 is a F 25, 210 is a 25 foot Sea Raider 309 is a 30 foot Sea Raider 301 is a F 30, 440 is a F 36 TriCabin, 460 is a F 36 Sedan, 500 is a 42 MY.
The fourth number or first number in the second set is the year. Hull number 321 7045 = F 32 year 1977 second set of three is its production number in this sample 045 is the 45 F 32 built since production started in 1970.
The problem with with the working hull number is that on large production boats like the F 32 some times the production numbering started over. So if you do not know if your Trojan was was build in the 70 or 80 then you would need the TRJ number as well to know if the 7 was 1977 or 1987
If you have a wooden Trojan 1945 - 1969 then she would only have a Trojan tag as described above or before 1955 she may only have the three number followed by four stamped inside of the transom, the engine stringers inside of the engine hatch.
If you need help with a TRJ number or Hull number Please call or or E mail Bob@Trojanboats.net
http://www.trojanboats.net/wforum/viewtopic.php?t=2957
TROJAN F BOAT MODEL NUMBERS
F 24 SPORT CRUISER MODEL 241, 242
F 25 EXPRESS MODEL 251, 252, 253
F 25 SEA RAIDER 210
F 26 MODEL 261, 262
F28 TWIN SCREW MODEL 280
F28 SINGLE SCREW MODEL 281
F 29 SPORTMAN MODEL 290
F 30 SEA RAIDER MODEL 309, 310
F32 EXPRESS MODEL 320
F32 MODEL 321, 322
F 32 SPORTS SEDAN MODEL 323
F 36 TRI CABIN MODEL 360, 363, 440
F 36 SPORT FISHMAN MODEL 461
F 36 CONVERTIBLE SEDAN MODEL 460
F 40 FLYBRIDGE MOTOR YACHT MODEL 400
F 44 CONVERTIBLE SEDAN MODEL 448
F 44 SPORT FISHERMAN MODEL 445
F 44 MOTOR YACHT MODEL 441, 442, 443, 444,447, 449
F 54 MOTOR YACHT MODEL 541
42 MOTOR YACHT MODEL 500, 501, 502, 503
44 MOTOR YACHT MODEL 441, 442, 443, 444, 447, 453, 454,543
48 MERIAN MODEL 480
53 MOTOR YACHT MODEL 701
53 DECK HOUSE SALON MY MODEL 702
Posted: Sat Oct 01, 2011 10:22 am
The reason I did not copy and paste the info is all the info is not need and can be confusing and miss leading on later years .we are dealing with a F30 only .
AND in many CASES the three model numbers are after the S/N number mid 70s on NOT the first 3 as I stated . You most likely not see the last 3 numbers on your registration or documentation but its on the hull .
Posted: Sun Oct 02, 2011 11:19 pm
by SweetOlive
Thank you all for the info :) I checked today & it ends in 302, so it is the Express! We had the bottom painted & the stripe it looks great.
Posted: Sun Oct 02, 2011 11:25 pm
by SweetOlive
Posted: Mon Oct 03, 2011 6:25 am
Looks Great
Posted: Mon Oct 03, 2011 6:26 am
by aaronbocknek
pretty vessel. she looks great next to the other boats in the marina. i love how these old ladies stand up against he best of them. have you noticed how they polish up? from what i'm told it is from the high amounts of zinc that trojan used in the gel coat. fiberglassers will also tell you that working on a trojan hull is very easy. for some reason, the resin that was used is very easy to work with when repairs are needed. same on older chris crafts, concordes, and hatteras boats from that era.
tri cabin aaron, baltimore, md
Posted: Mon Oct 03, 2011 10:01 am
by SweetOlive
We did try a test spot with the buffer & she shined right up! So that is our next project :) My Husband & I did not know anything about Trojan's before we purchased this one but we used to walk past her on the way to our sail boat & she always caught our eye, so when she went up for sale we were so excited & bought her as soon as her owner could meet us!
The more I learn about Trojan's the happier I am with the purchase!
[img][img]http://farm7.static.flickr.com/6158/620 ... 45d2a3.jpg[/img]
DSCF0672 by BrokenSpecialMuse, on Flickr[/img]
Posted: Mon Oct 03, 2011 10:14 am
by SweetOlive
Posted: Mon Oct 03, 2011 4:11 pm
by aaronbocknek
she caught your eye and sang her song. she picked you. i'm sure that all trojan owner will tell you that there is a mutual admiration society going on both here and out there. enjoy her. cant wait to see more pics.
Posted: Wed Oct 05, 2011 3:25 pm
by SweetOlive
Posted: Wed Oct 05, 2011 5:24 pm
Lookin Good :D
