Page 1 of 2
Marine Plywood??
Posted: Thu May 17, 2007 8:52 pm
by Sea Ya
Ok redoing my aft deck on the F26 I am using wood. Should i get marine plywood or nice sanded layered plywood and coat all sides very well with resin. I will be applying Epoxy to finished product. Comments, suggestions? Open to all advise. Besides having someone else do it :)
Posted: Thu May 17, 2007 10:01 pm
by Danny Bailey
I would start with the best materials possible. It is a shame to put many hours into a project only to see it start to come apart 1 or 2 years later due to a few 'saved bucks' on parts. Even if you do epoxy regular plywood on all sides, it will eventually get wet at fastener holes and dings. Use the marine ply.
Posted: Fri May 18, 2007 1:56 am
by pdm2q
yes use the the marine ply - we just did this as well, marine ply - and since its wood and against the outside conditions, no matter what type of sealer you use, you can never put too many coats on in my opinion (oh and this project is not hard at all, good choice at doing it yourself)
Posted: Fri May 18, 2007 7:13 am
by Paul
"Marine Ply" is the way to go. There are less voids in it than average ply, the adhesive used to laminate it is water proof & it's lighter weight than most ply wood.
easy
Posted: Fri May 18, 2007 2:04 pm
by JuiceClark
On a previous boat, I re-decked the cockpit. I was going to use marine ply then glass over it. But I happened to go on http://www.discountlumberliquidators.com
and found an odd-lot of unfinished 3/4" thick teak. It was ready to install and was the same price as just the cost of the marine plywood!
I had to let it turn grey though...was too hot on my feet.
Posted: Fri May 18, 2007 7:52 pm
by Sea Ya
thanks guys. What is cost there. I went to Cox and they want 120.00 per sheet. Is that hi? I need two sheets.
Posted: Sat May 19, 2007 3:39 am
by pdm2q
that sounds about right to me - i think we might have paid 120 or 130 - its definitely not cheap but its well worth it - it sucks now but in 3 years you will be glad to see its still holding up - good luck
Posted: Sat May 19, 2007 7:20 pm
by Sea Ya
Cool it said MOY or MOC or something?? It looked like it had a film on top. It was real smooth. Is that what I want? I am going to use a part Epoxy over it any forseen problems?
Posted: Sun May 20, 2007 9:44 am
by obeejr
MDO- Medium density overlay
Posted: Sun May 20, 2007 3:27 pm
by Sea Ya
obeejr wrote:MDO- Medium density overlay
Sorry new to this is that good for putting on boat dech to be epoxied over? The MDO
Posted: Tue May 22, 2007 6:48 pm
by Sea Ya
anyone?
Posted: Fri May 25, 2007 10:35 am
by randyp
See Ya,
Not sure if you already bought the plywood, but there is a company in FL that deals with all sorts of marine plywoods. site is http://www.worldpanel.com.
I used them a few years back to get some teak and holly plywood that I used to redo the cabin sole of my 77 F-26. Good prices and they know a lot about different marine plywood options.
Good luck
Posted: Fri May 25, 2007 2:12 pm
by Sea Ya
randyp wrote:See Ya,
Good luck
Randy No i have not made the purchase yet thank you sir I will def check them out Thanks again.
Posted: Fri May 25, 2007 2:13 pm
by Sea Ya
Good luck
OOPS still in bussiness? Look at the site :
Server Default page
If you see this page it means:
1. hosting for this domain is not configured
or
2. there's no such domain registered in Plesk
What you can do:
Using Plesk, you can create domains with web hosting on a single physical server.
For more information please contact Administrator.
Posted: Fri May 25, 2007 3:36 pm
by vabeach1234
Sea Ya.
Try it with out the last period after "com"
It works then.
