anti siphon valve
Posted: Sat Oct 29, 2011 11:31 pm
by larryeddington
I am installing new aluminum fuel tanks and the subject of anti siphon valve came up. The original had shutoff valves at the tank and right before the fuel pumpl.
I think and correct me if I am wrong, an anti-siphon valve is supposed to block the flow fuel in case of a line break lower than the tank. As the fuel pump draws fuel from the tank how does a valve know the difference from a leak?
Posted: Sun Oct 30, 2011 4:40 am
by alexander38
your right Larry it's a must have for a gasser
Posted: Sun Oct 30, 2011 7:28 am
by koviak
Larry, your fuel pump is drawing thru valve with vacuum so the small spring and ball release to flow. If a line leaks without vacuum the valve will not open.
Posted: Sun Oct 30, 2011 7:47 am
by alexander38
koviak wrote:Larry, your fuel pump is drawing thru valve with vacuum so the small spring and ball release to flow. If a line leaks without vacuum the valve will not open.
sorry was still 1/2 a sleep...
Koviak is right on the money..
Posted: Sun Oct 30, 2011 8:33 am
A leak wont have enough "pull" to open the valve . But you still should have cut off valve just in case .
Posted: Sun Oct 30, 2011 9:39 am
by larryeddington
Having a cutoff valve as well seems to be a good plan. My boat has copper fuel lines which I intend to retain. Presently the fuel exited the old galvanized tank via a cutoff valve and flared fitting on the copper line.
Seems like the only antisiphon valves I see are made with hose barbs for hoses. Is there one with threaded connection? I cannot locate one.
Posted: Sun Oct 30, 2011 6:32 pm
by g36
larry i replaced my tanks this year also and i did replace my antisiphon inline valves at the same time. i also reused my copper fuel lines but did install new antisiphons. if you will pm me i will be happy to give you the info on where i purchased them. these are the correct ones and not the barbed.
