Can you guys tell me where you have your transducers installed?
I asked this over the summer and one of guys suggested near the inboard stringer/stb engine.
Airmar has suggested moving it forward and closer to the centerline. I was thinking of the mid cabin/under the center seat.
Wondering if that might be too low/ easy to hit.
Thnks
Mid cabin - transducer location
before I cut a hole :)
You lift up the center mid cabin seat cushion to access it?
It will essentially be across from the AC seacock with the stringer in between, correct? Seems like a good spot, certainly nothing in front of it to create turbulence.
thanks
thanks
