transducer hole plug
Posted: Fri Dec 02, 2011 8:11 am
Someone asked a while back about an option to plug an old transducer hole. Here's what you need, Airmar part numbers:
33-417 @$20.30 ea
33-414 is the blanking plug for the 33-417 housing @ $16.82 ea
If you have a 2" hole, this is a good, permanent option w/o doing any glass work. It's basically a mushroom thru hull which sits almost flush and a blanking plug which goes in the middle.
The blanking plug is the same one that replaces the tri-ducer in Airmar's bronze units.
33-417 @$20.30 ea
