Page 1 of 2
Walnut hull blasting media to clean bottom
Posted: Mon Dec 26, 2011 10:49 am
by larryeddington
Has anyone had any experience with using Walnut Hulls as a blasting medium. Supposed to be very Gentle?
BTW I know and believe the best is Soda but am 60 miles out in the woods and my big blaster can use walnut hills but not soda. Will be difficult to impossible to get a soda blaster firm out here. :cry:
Posted: Mon Dec 26, 2011 2:15 pm
by DAVIDLOFLAND
Walnut shells were used on my F32 hull, and they worked great. The sandblaster's bill was $450, which I thought was very reasonable.
Posted: Mon Dec 26, 2011 3:19 pm
Walnut is ok to use , with a good user gelcoat should be ok .
Posted: Mon Dec 26, 2011 5:58 pm
by alexander38
you going to barrier coat her before paint ?
Posted: Mon Dec 26, 2011 6:15 pm
by larryeddington
I am pretty sure I will have to. Presently the bottom looks like the PO made a good start on sanding and filling in. To be on the safe side I believe I should. However once it is blasted I will rexamine.
If I barrier coat it looks to me the present recomended coating is Polyester resin type of paint, listening to opinions on PE or Epoxy for barrier coat.
Posted: Mon Dec 26, 2011 7:14 pm
by DAVIDLOFLAND
Best not to skip the barrier coat, no matter which system you choose. It's as easy as the first coat of paint.
Posted: Mon Dec 26, 2011 7:41 pm
larryeddington wrote:I am pretty sure I will have to. Presently the bottom looks like the PO made a good start on sanding and filling in. To be on the safe side I believe I should. However once it is blasted I will rexamine.
"Polyester resin type of paint," ? thats not a barrier coat .( not sure what it is LOL )
You have interlux 2000 barrier coat ( and similar products ) , vinylester or a epoxy .
Posted: Mon Dec 26, 2011 7:51 pm
by k9th
I'm using the Interlux 2000 on mine when they do it next spring. Pretty expensive but my research indicates it is a great product.
Posted: Mon Dec 26, 2011 8:25 pm
by larryeddington
kay paul vynal ester or whatever it is called. LOL
Posted: Mon Dec 26, 2011 10:19 pm
Its not called paint.
:shock:
Posted: Mon Dec 26, 2011 10:22 pm
3rd time I posted this link this week but its a good read
http://www.zahnisers.com/blisters_hydrolysis.htm
Not saying I agree with it all but a lot of info and it will make you think .
Posted: Mon Dec 26, 2011 10:54 pm
by larryeddington
Yep, I probably got an old can of latex wall paint around here somewhere, might keep fish out, if that don't work out too well, I'll get some of that vinyl stuff. LOL :lol:
Posted: Mon Dec 26, 2011 11:41 pm
I was trying to help, BUT FORGET IT ! paint away
:roll:
Posted: Tue Dec 27, 2011 3:45 am
by alexander38
larryeddington wrote:Yep, I probably got an old can of latex wall paint around here somewhere, might keep fish out, if that don't work out too well, I'll get some of that vinyl stuff. LOL :lol:
get some of that stuff that's in a can , it seals screen doors in john-boats you can it the as seen on tv section at walmart....not sayin'I agree with it...just tryin' to help.. :cry: :cry: :cry:
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Posted: Tue Dec 27, 2011 10:38 am
by Struts and Rudders
Prowlerfish,
Thanks for the article you posted.
I found it very easy to read and understand.
I will be using this information to resurface our hull...which by the way has no blisters.
SRD
F36
