borg warner velvet drives
antlr-king
Post by antlr-king »
i have 2 of these. they have this sensor with 2 wires going to it on the side. what is this for? and if i wanted to replace it where could i find one? thanks
1979 30' trojan express
Thats you neutral safety switch . It keeps you from starting in gear .
gettaway
Post by gettaway »
that would be your neutral safety switch, check continuity through both terminals in and out of gear.
1984 Silverton 37C
Silver Lining
Scott
antlr-king
ok thanks.
jefflaw35
Post by jefflaw35 »
WOW thats what a Velvet drive is suppose to look like???? :shock: :shock: 8) :lol: i need a smily face for Jealousy :lol:
Yup, neutral safety switch. If you know how to use an ohm meter, you should have continuity with the lever in the neutral position only. Continuity in any other position or no continuity in nuetral means a replacement. If you don't get a satisfactory reading, take it out and inspect, then bench test for continuity.
Eddie-O
netural safty switch
Post by Eddie-O »
To remove it do you remove the plate or just back off the big nut that has the 2 termanels on it
Just unscrew it .
antlr-king
lol this thing looked pretty bad untill i cleaned it. yes i will check that continuity on that switch.
antlr-king
had to bring this back real quick. engines are all in. im going to buy tranny fluid and engine oil. how much fluid does one of these trannys hold?
antlr-king
i just found out. they hold 2 quarts.
That can vary depending on the angle . I would put in a qt check and add some and recheck until you get it in range .
.....then run, shut down and check again. This will fill your lines and cooler.
