International - wetbar and bench legs
Posted: Tue May 22, 2012 8:24 am
The legs on my wetbar, L set and rear benches have been an issue since I bought the boat. The black factory rubber feet always left marks, some were gone and just had a screw head sticking down.
I tried different stick on and screw on HD/Lowes variety but nothing would stay on and the I continued to scratch the deck. I finally found a solution that is permanent, won't scratch or leave marks and allow you to slide things a little. It's impossible to "lift" and carry the wetbar or L seat especially if you're by yourself.
McMaster Carr - 1942K42 - SS threads with white/nylon slides, 2 3/8" wide. I used these on the wetbar and L seat, 7 of each
1942K72 - smaller version of the above w/ 1 3/16" base. I used four of each on the rear benches (total of 12).
About $175 for all of them. You'll need to drill larger hole and have the right SS nuts/washers to attach them.
