Senders for 318
- The Dog House
Senders for 318
Looking at the front of my 318, there is a small sender (1/4" NPT) below and to the left of the thermostat housing. There is also another "sender looking" thing directly below the thermostat housing that is bigger (1/2" NPT). The larger "sender" does not have any wires connected to it. What is this larger "sender"? Thanks for any enlightenment you can provide.
Former boat: 1971 Trojan F26
Probably the water temp alarm switch. You should pull it out, put in a pan with 1 inch boiling water and see if you get continuity. Or just purchase another one, install it and hook it up. It's a good alarm to have.
