Rocker arm assemble 360 chrysler 1978
Posted: Mon Aug 20, 2012 11:48 am
by Larrys78
I need a new rocker assembly for a 1978 360 CID does anybody know a automotive part number so I can pick one up at NAPA or what engine I should tell them to refer to
Posted: Mon Aug 20, 2012 3:53 pm
by Stripermann2
Do you just need the rocker arm...or the shaft assembly? Bob can get you the parts you need here:
http://www.trojanboats.net/PriceLists/C ... ts%202.pdf
The 318, 340 are also interchangeable.
Rocker, right is PN 4100774. rocker left is 4100775
Shaft number is 2532149
Or, just call NAPA and ask them to look up what you need.
Posted: Mon Aug 20, 2012 6:55 pm
by larryeddington
I haved a complete set of 318 head witn intack valve gear if it will work. Am not long for carrying it to the recycler. Heads had about 900 hours on them but block damage due to freezing.
