318 engine module is it the same as automotive
l7ty15
Post by l7ty15 »
Is the ignition module same part as automotive...mine died at the dock...changed port to starboard...module is dead but I can't find part numbers
Tri-Guy
Post by Tri-Guy »
Yes its the same part as auto at half price, the pin count doesnt matter they both work. Also the box has no spark so no bildge problems.
g36
Post by g36 »
yes it is as above stated
heres one from pepboys where i live sure yours will be the same
also autozone or advance auto also
http://www.pepboys.com/parts/ignition_s ... -V836059L/
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
l7ty15
Post by l7ty15 »
Thanks guys....that will be another spare I will carrying onboard from now on....
l7ty15
Post by l7ty15 »
Lawman
Post by Lawman »
Tri-Guy wrote:Yes its the same part as auto at half price, the pin count doesnt matter they both work. Also the box has no spark so no bildge problems.
Tri-Guy..Why does'nt the pin count matter?? Just wondering.
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
Tri-Guy
Post by Tri-Guy »
Not sure why the pin count doesnt matter, my friend had one with the wrong count and it worked. After I saw him do this I asked around and got the same answer that the boxes are the same and its ok to use.
The #3 pin isn't used in some applications. Plug is set up for 5 pins but some only have 4 there. #3 usually used in a dual ballast application otherwise not needed.
l7ty15
Post by l7ty15 »
Fyi canuck boaters......shop out these parts.....I started at a high of $120 all the way down to $16........no reason not to have spares at that price.....especially given how easy it is to change out with out tools....
Lawman
Post by Lawman »
Thanks for the info...It sould be illegal to charge 5 times more just because it's for "marine use" !
' Goomar '
