Page 1 of 2
Boat Delivery Day
Posted: Fri Oct 05, 2012 10:22 pm
by FLRAVEN
Posted: Fri Oct 05, 2012 10:32 pm
by k9th
Nice looking boat. Thanks for the pics & welcome aboard.
Posted: Sat Oct 06, 2012 6:22 am
by RWS
Pics look good
After replacing two macerator pumps in 4 years I switched to a simple diaphraghm pump - it's just another vacuflush pump.
zero problems since doing that 6 years ago!
plus if we were out somewhere and the main vacuflush pump went out in a desperate situation, I could swap pumps to keep running.
Also, while that pump is far more expensive than the macerator, it has replacable parts in it.
When you gat a chance, send more photos.
Posted: Sat Oct 06, 2012 6:55 am
Nice
Posted: Sat Oct 06, 2012 8:40 am
by RWS
these vessels were factory equipped with a bilge alarm.
in each of the 3 bilge compartments there is a second float switch, identified by a large yellow label (see below)
They are each tied to the horn relay.
it's on the wiring diagram
in some cases they were disconnected or removed by unknowledgable technicians
photo below
Posted: Sat Oct 06, 2012 8:58 am
by aaronbocknek
she's beautiful!!! i love the bottom paint color and boot stripe. the hull looks like she was just waxed and detailed. keep us posted and more pics would be great. and, of course, welcome aboard.
tri cabin aaron, baltimore, md.
Posted: Sat Oct 06, 2012 10:16 am
by FLRAVEN
Posted: Sat Oct 06, 2012 2:12 pm
by jhalb
I'm jealous of your cushions. Nice looking boat.
Posted: Sat Oct 06, 2012 2:45 pm
by RWS
hold on a minute,
looked at the photos.
clearly this vessel has undergone several notable custom makeovers.
Would like further information refarding the custom work done in eliminating the sliding lexan door.
Also, how does one access the engine room?
Posted: Sat Oct 06, 2012 2:55 pm
by RWS
the aft bilge pump is in fact in the correct location, between the single fuel tank and the transom.
When on plane, this is the lowest point of the boat.
This also applies if you are stored on a lift (like mine)
In the express version I believe the vee of the keel connects the rear bilge area to the front bilge area.
At rest, the fwd bilge area is generally the lowest part of this boat (can vary depending on equipment weight distribution)
The (rain/wash) water you see collecting in the bottom of the lazarette is actyally collecting in the rear compartment liner - seperate from the actual hull.
Two minor improvements can help this
one is to drill a small drain hole - 1/4" max in the bottom of the LINER ONLY in the lazarette (veirify that you have a LINER before doing this) this little drain willlet water gravitate from teh liner to the inside of the hull.
the other is in the event you ever take the gas tank out foir any reason, it's a good idea to remove a section of the liner exactly where the aft bilge pump and switch are.
this way the pump and switch can be more effective in removing more water from the boat.
Posted: Sat Oct 06, 2012 6:06 pm
by FLRAVEN
The sliding lexan door was replaced with a pair of hinged teak doors and a hinged teak cover that matches the shape of the odd shaped opening. The engine room is accessed by the center cover. The cover was cut in half and hinged so that the forward section opens by folding aft. However I have now removed all of the deck furniture and carpet in order to open all of the engine room hatches. This is much better access for all of the cleaning and other work I plan on doing.
Posted: Mon Oct 08, 2012 6:23 pm
by RWS
more photos, please.....
Posted: Tue Oct 09, 2012 7:33 pm
by FLRAVEN
Posted: Tue Oct 09, 2012 11:33 pm
by todd brinkerhoff
Nice looking boat. Someone did some nice craftsmanship. They are great boats. Enjoy!
Posted: Wed Oct 10, 2012 4:55 am
by aaronbocknek
love the retrofitted cabin door. great woodwork.
