Run Dry impellers?
Posted: Sun Nov 25, 2012 6:55 pm
by AndyF32
Has anyone tried running the "Run Dry" impellers? I have Crusader 270's with what I believe to be the sherwood E35 pumps and was thinking of trying the Globe run dry impellers. Any opinions?
The only time I worry about the run dry aspect is during winterizing when I am feeding antifreeze into the sea strainers and is is hard to keep up with the pumps.
Posted: Sun Nov 25, 2012 10:44 pm
I had good luck with them on a 671 DD I had And sold then years back with no complaints I remember .
I would still not recc to run any pump dry
Posted: Mon Nov 26, 2012 10:15 pm
by AndyF32
Thanks for the info.
I have no intentions of running them dry it is just when winterizing I cannot pour as fast as the pumps pull the antifreeze from the sea strainers. I am sure the pumps do not get dry but are just not fully flooded at times.
Posted: Tue Nov 27, 2012 8:27 pm
by aaronbocknek
anti-freeze is a lot more slick than water and as long as you don't let it run too long, you should be okay. at least that's my take on it.
