Hello,
I am an electrical engineer, master electrician, and electro/mechanical tech. A fellow has asked me to redo the wiring in his twin engine Trojan boat. I have almost no familiarity with marine wiring, but hoped that you all could help me out. I am looking for electrical and or mechanical schematics and any other technical documents which might be useful. The hull number of his boat is 501 1008. I am not sure of the model, but was hopeful that is might be decernable from the hull number.
Engine 1# is 440 4596
Engine 2# is 440 0735
Any help or referrals would be greatly appreciated.
Gentleman wants me to rewire his boat
hull #
Really need the year and model #. The last 2 digits of the hull # are typically the year, but 08 can't be right....
Can't help with specifics
Can't help with specifics on a 72 Sea Voyager, but will reinforce the obvious:
- > tinned copper wiring (Ancor is the best),
> go a gage larger (14!) minimum while you're at it,
> heatshrink adhesive lined crimp ring terminals,
> 2 port, 2 starboard and 1 large house battery, with marine selector switches (Guest or Blue Sea) to intercionnect between them ( for startign in an eergency)
> 2 rear and 2 forward bildge pumps, with automatic floats and manual switches wired to seperate batteries (1 each front and rear to one each of the stbd and port batteries)
> chargers!
> throw away those old Perko lights and put in LEDs while you're at it
> solar panel(s) to feed 1 or more batteries "just in case"
> the list goes on ...
