Trojan F28 sink and shower question.
Posted: Mon Oct 15, 2007 8:28 am
by moparmel
Hello, I was wondering where my shower and my sink water run to when they go down the drains, into the bilge? It :?: :( seems my front pump comes
on and over every 5 minutes, it only runs for 3 or 4 seconds and shuts off.
Sometimes it spits water and other times it does not. I also noticed under
the floor near the bathroom a hose and on the end of it looks like a filter,
what would this be???]
Posted: Mon Oct 15, 2007 1:57 pm
by fpawn1
on the f-32 the sink hose goes directly out on thru-hull fitting; the shower should drain into a pan with a seperate pump; there is an filter before--on the f-32 it is in galley floor; maybe one of your hoses has a hole sending water to the bilge
Posted: Tue Oct 16, 2007 11:58 am
by Dreamer
Some F28's drained the shower into the bilge. Sink water went out the side.
Posted: Wed Nov 21, 2007 4:05 am
by dcal456
My 76 F28 shower pan goes into a diaphram pump then into a thru hull fitting
Head sink into a thru hull fitting
nothing into bilge that would be nasty for grey water
Control for shower pump switch bulkhead in head
