10 meter exhaust question?
Posted: Mon Mar 11, 2013 11:41 pm
by bigrgh
I am replacing the exhaust on my boat and i have come across a part that i cannot find. crusader 454's,exhaust manifold to spacer to riser to elbow -after the elbow, rubber hose connects the left and right side to a 3" cast metal "t" that looks to have a deflector inside to help with water flow. that is the part i need to find. what is it , who makes it , what part number,in all my research i have not come across it. any help will be appreciated.
Re: 10 meter exhaust question?
Posted: Tue Mar 12, 2013 6:50 am
by RWS
Try Beacon/Marine Tech.
Have that diverter machined out before installation for better flow.
Posted: Tue Mar 12, 2013 9:06 pm
by yorklyn
I replaced one when I first bought my 10 meter. I special ordered it from west marine but that was quite a few years ago. I actually need to get another one because my worker dropped one and cracked it. I was trying to find a fiberglass "Y" instead of the cast but havent had any luck yet. I'll let you know when I find something.
Posted: Tue Mar 12, 2013 9:37 pm
by Big D
Is there something here that will help?
http://www.centekindustries.com/fittings.html
Posted: Tue Mar 12, 2013 9:51 pm
by yorklyn
Big D, Your the Man! Thats what I've been looking for. Thanks!
Bigrgh, If I'm at west marine this week I'll see if I can find any info on the cast fitting.
Posted: Tue Mar 12, 2013 10:19 pm
by Big D
Any marine dealer that carries Centek products should be able to order what you need if they don't have it in stock.
Posted: Tue Mar 12, 2013 10:28 pm
by yorklyn
Posted: Tue Mar 12, 2013 10:54 pm
by gettaway
do yourself a favor and switch out the old heavy rust prone cast 'wye" or "Tee" fitting and replace it with a fiberglass wye or tee.
Vernatube or Centek are two of the brands, Beacon may carry them or can get them for you, or google "fiberglass marine exhaust parts" or ask your local chandlery
the fiberglass tubes will not corrode, will handle fairly high heat (equal to or higher than the rubber exhaust hose) and are easy to work with.
good luck!
Posted: Thu Mar 14, 2013 10:34 pm
by bigrgh
the cheapest i found them is at deep blue yacht supply, 65 bucks each thru Amazon with free shipping. the fiberglass ones are around 180 bucks.lighthouse marine has them also but at 80 bucks. plus shipping. thanks for the help
Posted: Thu Mar 14, 2013 10:35 pm
by bigrgh
