F-25 fresh water tank
Where do you fill the fresh water tank on an F-25?
- The Dog House
Re: F-25 fresh water tank
My F26 has a deck fitting on the port side near the front window to fill the water tank. I'm not sure if the F25 is the same or not.
Former boat: 1971 Trojan F26
Thanks TDH. My fuel and waste figttings are on the port side. Next time I'm out I'll look closer towards the bow.
- aaronbocknek
as on any vessel, there should be a clearly marked deck fitting that says WATER engraved on the screw cap fitting. not exactly familiar with the f-25, but all trojans had engraved deck fittings.
Thanks!
On the early 25's (wood deck) there is a cover plate on the cockpit deck under the port side seat. If you lift up the plate you can open the top of the water tank and stick a hose in.
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
