Bennett trim tabs
Bennett trim tabs
I have a 1980 F26 that stays in its Keuka Lake slip most of the summer, but I enjoy Fall boating after things a a little more quiet on the lake. I noticed a few days ago that my trim tabs were not working -- motor sound for each of the tabs, but no movement. Based on the info. I found in a search on this site, I was guessing that there was probably an electrical issue (not enough juice to the solenoids). I have spent most of the last couple of summers tracking down gremlins, so wasn't surprised to find my tabs problem could be electrical (thinking yet another corrosion issue -- the kind I thought I was done with when we moved from salt water (or brackish, anyway) in Maryland.
Anyway, I found today that there was little or no fluid in the unit, so I corrected that first. It turns out, that solves the problem for now. I found, though, that the left and right hoses are reversed at the control unit. Is this something that should be corrected? The switch is correct for right and left (and up/down), so I'm thinking maybe a prior owner had the left and right leads reversed somewhere, and just decided to reverse the hydraulic lines to correct the problem. I haven't pulled the switch or done any other checking yet, and would rather not mess around with the hydraulic connections on this 1980 boat. Other than that issue, the lexan cover is cracked/split at the rear, but still screws in place (pump motor and solenoids under the cover appeared to be very clean). The clicking of the solenoids is not real easy to hear, although they are clearly working as the tabs are now operating. So, anybody have any thoughts??
By the way, there is a black box with a 16 amp circuit breaker button on the bulkhead at the port side of the engine -- marked "trim tabs". The breaker was OK, as would be expected since the control button for the tabs was working. For the record, there is also a breaker/reset button under the helm and fuse panel -- also the red plastic key for the electrical system. This breaker popped once early on when I was trying to dock -- immediately shut down the motor so I guess that breaker is for the ignition switch and maybe nothing else (hasn't happened since, but I'm still a little spooked.) In addition, there is a panel for the A/C shore power and onboard charger in the storage compartment on the passenger side. The charger makes a buzzing sound when doing its thing. (Somebody had wondered about that in one of the posts I found -- instruction booklet for the charger says the buzzing is normal, and tends to quiet as the batteries reach full charge. I haven't noticed any difference in sound, though, and the batteries were brand new this Spring.)
1980 F26, Mercruiser 305
Re: Bennett trim tabs
The tabs are normally are wired so the left switch works the right tab and right switch to left tab.
However some people don't like them that way the prefer right to right left to left . I am one of those people .
I would not worry about the hoses if it works the way you want it , if not switch the hoses .
interesting. I assumed the left switch operated the left (port) tab, and the right switch for the right tab, as you suggest may be preferred. Seems the most intuitive to me, but maybe that is why the lines are switched. good tip.
I should add that the lines appear to me to be reversed with the outlets facing the bow of the boat, as is the arrangement in mine. Maybe the unit is meant to have the hydraulic outlets facing the stern (which would make some sense), in which case left would be left and right would be right. makes my head hurt.
I didn't make a note of the solenoid wire colors on the "right" and "left" in my boat, and it just struck me that would be the way to figure out what hydraulic outlet was intended for what tab.
Uhh huh???oldboat1 wrote:interesting. I assumed the left switch operated the left (port) tab, and the right switch for the right tab, as you suggest may be preferred. Seems the most intuitive to me, but maybe that is why the lines are switched. good tip.
Tabman ( a expert from Benett ) has posted some diagrans here you maybe able find them . Or maybe he willl see this and respond .
If you have the rocker switch, the left button operates the starboard Trim Tab and the right button operates the port Trim Tab. This is the way the system comes wired from the factory. The reasoning is that the you push the switch in the direction you wish the boat to respond. For example if you wish to lower the starboard bow, you would push the right hand upper button. This will lower the port Trim Tab which in turn would lower the starboard bow.
The solenoids for each side have a read and green wire. Red for the port valve and green for the starboard valve (just like running lights). There are also a small "P" & "S" molded above each outlet to identify which they should be connected to. The green valve (starboard side) is on the right when looking at the face of the pump, and red is on the left.
Some people do like the switch to operate the other way around, so that the right hand operates starboard and left operates port. This is fine and may be accomplished by swapping the tubing or exchanging the position of the red and green wires on the back of the switch.
It is unusual for a system to loose all its fluid, so you should closely inspect yours for leaks. One way to do this is to fully lower both Trim Tabs and leave them there overnight. They should stay down. If one or both retract on their own inspect for leaks and let me know what you find.
Tom McGow
Bennett Marine
Tom McGow
Bennett Marine
Tom,
Would it now be safe to say TABMAN UP ?
Tabman is indeed back up and runningRWS wrote:Tom,
Tom
Bennett Marine
- The Dog House
Welcome back Tom. Glad to hear the seas have calmed a bit for you.Tabman wrote:
Tabman is indeed back up and running![]()
Tom
Bennett Marine
Former boat: 1971 Trojan F26
- aaronbocknek
YEAH!!!!!!! THE TABMAN IS BACK UP AND ABOUT. you've been in mine (our) thoughts and prayers. so stoked you're here posting.Tabman wrote:Tabman is indeed back up and runningRWS wrote:Tom,
RWS![]()
Tom
Bennett Marine
aaron
Thanks guys! The kind thoughts and prayers of all my internet fiends was, and continues to be, a big factor in my recovery.
Tom
Tom
haven't checked the boat today, but found some seepage around one of the hydraulic line connections. There could be a slow leak that I had not noticed. The boat is very rarely run, and the leak was probably an ongoing problem even before I took possession, so that's probably the story on the problem -- tightened the compression connection slightly on the leaking outlet, and that may be enough to solve the problem. I expect to take the boat out tomorrow. If the tabs are working, I'll follow Tom's advice and lower them overnight to see if that affects the fluid level.
Tom -- best regards. Advice appreciated.
Not to swipe a post...
Tom I'm glad to see your doing better, I'd like to thank you for all the help you gave me last off season. My 3607 now gets 1.6 nms per gallon per engine (454's black ones) and will stay on plane at 11 knots! One of the best things is the wife finds it alot easier to handle in quartering seas...thanks again.
Alexander38,alexander38 wrote:Not to swipe a post...
That is so cool to hear! I am delighted I could help!
Tom
Bennett Marine
Sorry for Hijack but I wanted to thank Tom the "Tabman" for all the help he gave me when I sent him a PM the other day!
Thanks Tom!
Thanks Tom!
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
