Page 1 of 3
What Did You Get For Christmas?
Posted: Thu Dec 26, 2013 10:36 pm
by The Dog House
What did everyone get for Christmas? My big present was 20 feet of 1 inch ID Shields Flex II hose. I plan on replacing most of my hoses this Spring.
Re: What Did You Get For Christmas?
Posted: Thu Dec 26, 2013 11:21 pm
by 44Ydnar88
I would like to chime in on this one. There under the tree sat a brand new dometic msd porta potty. I have not been that happy to see a toilet since my last trip to white castle! I recently removed the vintage jabsco electric over board discharge toilet. No room for a holding tank port side, as my new house bank sits there. And.... Since my wife loves me so much and my birthday isthe 27 of Dec, along side that shiny new head was a 19" led DVD combo. Merry Christmas!
Posted: Fri Dec 27, 2013 4:38 pm
by kevinz
My employees gave me a Garmin 4kw radar. Great gift and really wanted/needed. Here is the problem. I was going to get a radar when I was ready to tackle a big project. On the Trojan 350 express, the radar arch is not flat, it has a curve fwd to aft in it. A store bought radar mount will not work. I have to get the welder out here to take messurements. Then the GPS antenns has to be re-located. The mast light bar might have to be moved also. I was going to go through all of this when I needed to replace the canvas because I want to raise the arch up 8 inches. (I'm tall) So now I will have another $500.00 in mounts and maybe more if I get the custom mount powder coated.
Posted: Fri Dec 27, 2013 6:38 pm
by jhalb
My stepson got me a bug zapper for the dock. I got my wife a Mini Glo electric fireplace to take back and forth to the boat.
Posted: Fri Dec 27, 2013 6:59 pm
by Stripermann2
Just kidding...not too much in the way of boating items but some cool bluetooth electronics, clothes, gift certificates. Very nice Christmas.
Posted: Mon Dec 30, 2013 8:54 am
by RWS
Posted: Mon Dec 30, 2013 9:52 am
Dam ! Thats what I want .
Posted: Mon Dec 30, 2013 12:38 pm
by rmatt
Posted: Mon Dec 30, 2013 12:50 pm
by gettaway
kevinz wrote:My employees gave me a Garmin 4kw radar. Great gift and really wanted/needed. Here is the problem. I was going to get a radar when I was ready to tackle a big project. On the Trojan 350 express, the radar arch is not flat, it has a curve fwd to aft in it. A store bought radar mount will not work. I have to get the welder out here to take messurements. Then the GPS antenns has to be re-located. The mast light bar might have to be moved also. I was going to go through all of this when I needed to replace the canvas because I want to raise the arch up 8 inches. (I'm tall) So now I will have another $500.00 in mounts and maybe more if I get the custom mount powder coated.
I wish I had your problems ....
try these guys,
https://sites.google.com/site/seascanra ... dar-mounts
Posted: Mon Jan 06, 2014 10:10 pm
by wolfnnj
A fusion Marine stereo
A Fusion Marine Bluetooth adapter
6 Pyle Marine speakers
Two GE waterproof LED color light wires (1 red 1 green) to be mounted on VHF antenna on right and FM antenna on left so when my running lights are on I'll have red and green glowing antennas and be seen for miles.
It was a very mari ner Christmas for me
Posted: Tue Jan 07, 2014 11:51 am
by Big D
wolfnnj wrote:....
Two GE waterproof LED color light wires (1 red 1 green) to be mounted on VHF antenna on right and FM antenna on left so when my running lights are on I'll have red and green glowing antennas and be seen for miles....
Don't think you can do that. They are not supposed to be seen past a certain angle as someone approaches from behind. Nav light housings are made with specific angles in mind. It would be like adding red lights to the front of your car. It makes it more difficult to tell which direction the vessel is moving, and the colours would be on the wrong side....confusing to an approaching vessel. You may want to check regs on that.
Posted: Tue Jan 07, 2014 11:55 am
by wolfnnj
I checked they are mounted on the side of antenna and are only visible from front and rear and the side as the antenna blocks it from being viewed from the wrong side
Posted: Tue Jan 07, 2014 12:05 pm
by Stripermann2
wolfnnj wrote:I checked they are mounted on the side of antenna and are only visible from front and rear and the side as the antenna blocks it from being viewed from the wrong side
You shouldn't be able to see the red or green from astern...the port and starboard lights should only cover an arc of 112.5 degrees, from ahead or slightly off center from ahead.
Posted: Tue Jan 07, 2014 12:16 pm
by Big D
I think it'll look smart but you may be treading on dangerous ground with the coast guard and other law enforcement. The angles are very specific for a reason. Here are some graphics that may help.
http://www.westmarine.com/webapp/wcs/st ... ight-Rules
https://www.google.ca/search?q=boat+run ... B580%3B270
Posted: Tue Jan 07, 2014 12:48 pm
by comodave
Not only must the side lights, red and green, be seen for the 112.5 degree arc of visibility and only 112.5 degrees, you can not show multiple red and green lights on vessels of our size and usage. When you start adding lights, you are telling other vessels that you are a different size and/or usage vessel. You then may/will incurr some liability if you are involved in a collision. Ask your insurance company if they want to pay a claim when your boat was improperly lit... That is why navigation lights have to be certified to CG regulations. When you start modifying or adding to your nav lights, you need to be very careful.
