Finally out of the water - Trim Cylinder Shear Pins
Posted: Fri Aug 01, 2014 11:59 am
Well, she's out. The 4 things that I originally wanted to do to her while on the hard have turned into about 12. A few things revealed themselves that need attention once I had a chance do a once over.
Anyone have problems with the Trim Cylinder shear pins deflecting or breaking? See photo below.
I ordered new ones and I think that the metal bracket that I have maybe causing issues with the pins (or the pins may just be old) so I ordered the newer cylinder brackets as well. Hopefully this will fix the issue. Looks like the brackets that I ordered would provide more surface for the pins to bear on than just a thin metal bracket. God I hope the holes line up between my current brackets and new ones.
