sherwood E35 major rebuild
Posted: Sun Nov 30, 2014 3:25 pm
by larryeddington
This pump has been written about before but I cannot find the answer to my question. All is straight forward, replace bushing, seal and impeller. Now comes the front bearing which is retained in the front with a large inner circlip and on shaft by a smaller external circlip at the shaft. The bearing shaft cannot be pushed towards the impeller end and cannot be pushed forward with out removing the large internal circlip. To remove it would not be a problem other than the pressed on hub is in the way.
So my question how do I get her apart, me thinks I have to press the hub off, any experience as to the question? The bushing should come out with and internal bushing puller.
Re: sherwood E35 major rebuild
Posted: Sun Nov 30, 2014 6:58 pm
by larryeddington
Guys, disregard, I did a total rebuild and yes you have to pull or press the pully hub off, mandatory. Was not too bad when you have the tools to pull and press pieces apart and together.
Posted: Mon Dec 01, 2014 9:08 pm
by Scorpion07
If you haven't put it back together yet, this is a great step by step reference. Direct from the source.
Where did you get your rebuild from?
http://www.sherwoodpumps.com/FileAttach ... NGLISH.pdf
Posted: Tue Dec 02, 2014 9:19 am
by larryeddington
Thanks already reassembled. What was unusual is the instructions with the major kit indicated some screws that could be removed and the shaft bearing assembly pushed out. Not so I pulled the hub and continued as with other Sherwood pumps. All done, thanks.
