Holding Tank
Posted: Sat Oct 17, 2015 1:41 pm
by larryeddington
What is the best place to purchase or have made a new holding tank for my tri-cabin? It is 30Lx22Wx14H should be about 40 gallons. I want one that uses a dip tube from the top for clean vacuum.
Re: Holding Tank
Posted: Sat Oct 17, 2015 2:28 pm
by comodave
I have had good luck with Ardemco. They will put the fittings where you want them. You should think about putting in 2 vents while you are having a new tank put in. I like 2 1" to 1 1/2" vents, one going to each side of the boat. It will get more oxygen into the tank and help control the anerobic smells.
Re: Holding Tank
Posted: Sun Oct 18, 2015 9:35 pm
by WayWeGo
Re: Holding Tank
Posted: Mon Oct 19, 2015 12:56 pm
by larryeddington
Using Ronco Plastics cost is around 250 with shipping incl.
Re: Holding Tank
Posted: Mon Oct 19, 2015 4:23 pm
by P-Dogg
If it comes via truck freight, inspect it very very carefully before signing for it. Unwrap it, use a flash light, look at the bottom -- everything. Can you tell I've had experience in this matter?
Re: Holding Tank
Posted: Mon Oct 19, 2015 5:04 pm
by larryeddington
well ya I check everything. it will come ups, truck yes but not heavy freight.
