PLACEMENT OF TRANSSDUCER
Posted: Mon Mar 17, 2008 10:57 pm
by GARYGA
HELLO AGAIN, ANYONE OUT THEIR KNOW THE BEST PLACE FOR ME TO PUT MY THROUGH HULL TRANSDUSSER. MY F308 TROJEN HAS A KEEL FOR ABOUT TEN FEET TO THE AFT OF THE BOTTOM. I WAS GOING TO PUT IT IN FRONT OF THE THE INBOARD PROPS BUT THEN THATS WHERE THE KEEL IS. IM NOT SURE YET WHERE THE BEST PLACE TO MOUNT THIS WOULD BE. THANKS
GARY GA ( STILL LEAVING FOR THE BIG TOW TO NY, 30 DAYS AND COUNTING)
TRANSDUSSER IS FOR CHARTPLOTTER, FISH FINDER DEBTH, TEMP ECT.
Posted: Tue Mar 18, 2008 9:20 am
by Stripermann2
Mine are between the engines, just starboard of the centerline. There are fairing blocks which keep it pretty well faced down, since the ducer is on the angle of the hull.
Don't put it near prop wash if possible.
You can check out Airmar. They are the manufacturers of just about all ducers for most companies.
http://airmartechnology.com/airmar2005/ ... D=0&NewID=
placement of transduccers
Posted: Thu Mar 20, 2008 12:35 am
by GARYGA
Thanks Jeff..........
Stripermann2 : thanks for your reply. when you were (are) between the engins is your center line the keel which is what my trojan has when i get up near the engins. this seems like a good place but im concerned about the keel being to close. after i here from you i will also check out airmar like you suggested. thanks gary
Posted: Thu Mar 20, 2008 8:39 am
by Stripermann2
Gary, yes, starboard of the keel. Just a few inches inside of the Starboard engine stringer. (Between the keel and the stringer) I also have another one in the rear of the boat, just port of keel 2 feet before the transom.
