I can see spring and water
Posted: Wed Apr 02, 2008 11:52 am
by rick1954
I have to ride by my little Seascape every day on the way to work, She keeps calling out to me as I ride by “ Rick Rick get on board†“ oh don’t forget the beer†that is my girl LOL. Most all the snow is gone now with the 65 deg day we had yesterday . I cant wait to pull the shrink wrap and start working. I am going to add that el fuel pump as soon as I get on her, I know that someone done this is there a size i should get to handle the flow of gas this tank needs?
Just started to install the filler pcs for the swim platform, the one that I restored off the boat was stright across and I want it to curve with the back of the boat, so to the lumber yard for some 5/4 teak Boy I do love to make my self work but it is worth it.
Posted: Wed Apr 02, 2008 5:47 pm
by jimini
Electric fuel pump > figure out how many gallons a hour you max out at and add 10% to that number to be on the safe side
Posted: Thu Apr 03, 2008 9:35 am
by randyp
Rick
I've maxed out at 15 gal/hour on my F26 w/ Chrysler 318/225 hp 4bbl carb. Your engine probably will do better. Hope that helps.
Posted: Thu Apr 03, 2008 9:59 am
by Stripermann2
Rick, I can see the spring and the water...from my flybridge with a cold beer in hand too!
Just got Floscans for the boat, looking forward to filling the boat up and keeping tabs on my consumption and fuel usage from now on...
Those fuel gauges are just plain worthless.
Floscans
Posted: Thu Apr 03, 2008 10:10 am
by TADTOOMUCH
Are Floscans hard to install on a 1978 F-32 with twin Chrysler 360's. I just got a Raymarine C-120 display and would love to send floscan data to the C-120 and use the floscan gauge.
Posted: Thu Apr 03, 2008 11:08 am
by Stripermann2
No...
The plumbing goes right in after the filters. Then you run the wiring to the gauge. I have the twin scan, which reads and and totalizes both engines and is resettable.
Top off my tanks at 220 gallons. Keep a running total on fuel burn. If I burn 100 gallons in a given time, I know I have 120 gallons left!
http://www.floscan.com/html/blue/series ... 14&catid=2
Posted: Thu Apr 03, 2008 12:55 pm
by rick1954
Thanks I think that will help, just want to make sure that I get a large enough pump.
Flybrige and cold beer OUCH
I cant even get on my boat yet
Posted: Fri Apr 04, 2008 11:07 am
by rick1954
All the snow is gone around my boat, the water should be in the basin within a few weeks and I will be floating. I fond the Holly marine electric fuel pump that should deliver the fuel needed to run that little 351FI engin and will be installing it in about two weeks. That is when I will be taking off the covers and removing the dust from the good old gal and get her ready. I wish I was in a warmer climate like most of you guys on this forum but some of us have to be in the cold and snow
It make it that much more exciting when you put back in after a long cold winter.
