I notice on my starboard engine that the alarm does not sound when I begin to start it. Its a 1981 F 32, where is the alarm located??
F32 ignition alarm
Re: F32 ignition alarm
Under The gauges/helm Looks like a relay .
so to get at it, have to unscrew gauge panel and lift it up??? Is it a easy repair??
Just look underneath , I assume your talking about the fly-bridge ? should be close to other engine alarm so you can turn it on to here where its at
I meant to say it was the lower station
On my 75 F32 You access the lower station through removing the wall panel in the dinette area.
Trojan F32 Flybridge 1975
Twin Ford 351s
Albany N.Y.
Twin Ford 351s
Albany N.Y.
thanks. thats a good point and will check that out tonight
