bottom painting
- farfrompuken
bottom painting
OK gentlemen, what do you guys paint and don't you guys paint? props, shafts rudders,trimtabs, strainers, all ,some and/or which ones?
'72 F-31 Express Flybridge JUST US TWO
Twin 270 Crusaders
16' Glassmaster Center Console
hangout:ZACKS BAY Long Island ,New York
http://s390.photobucket.com/albums/oo350/farfrompuken/
George and Joanne Holzmacher
Twin 270 Crusaders
Rodman wrote:do you think if I use low vol sand blasting on the bottom it will hurt it? I want too repaint mine as well.
I posted twice
9
I would start with a 3000-4000 psi pressure washer with a 0 degree oscillating tip first , , if more cut is needed u can get a attachment for sand or even better glass beads, always do a small test spot first, light scratching is OK in fact it helps tooth the barrier coat but chipping is bad
It worked well on my boat with a soft ablative . but my friends boat had a hard paint and it did not do as good, he ended up sanding it down with DA sander with 60 grit barrier coat and 2 coats of paint,
9
9rock wrote:Rodman wrote:do you think if I use low vol sand blasting on the bottom it will hurt it? I want too repaint mine as well.
9
Thanks for the info.
Trojan
Re: bottom painting
I paint all except zincs and transducersfarfrompuken wrote:OK gentlemen, what do you guys paint and don't you guys paint? props, shafts rudders,trimtabs, strainers, all ,some and/or which ones?
9
choice of paint equally important.
Match the paint to the water and consider if the boat comes out of the water.
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
We use soft ablative paint on the bottom and Future acrylic wax on the props and shafts. Tried it last year after an old timer told us about it seemed to work pretty good. Also put Cayenne pepper in the bottom paint.
Hank Newman
"Winsome" 1979 - F30 Clean Machine
First Sergeant, U.S. Army Retired
Co-Owner Don Snyder
Co-Owner Don Snyder
