Leaky F32 Bridge/Ceiling
jordan
Leaky Flybridge
Post by jordan »
Our 76 f-32 leaked water out of the overhead switches and puddles would gather on the dash in front of the lower helm, it would build up enough that it would drip all over the dinette. I removed the gutters and found very large gaps, up to a 1/2 inch. I used two part epoxy and went all the way around the bridge filling it as smooth as I could with out getting any on the areas that would show after I re-installed the gutters. I than re-drilled all the holes and used a small amount of 5200 on each hole. By using the two part epoxy to fill the old holes it allowed the new screws to bite in to a firm hold. The leaks have not come back.
Jim
SHEGAVEIN (F-32)
Capt. Jim Jordan
Nancy
Post by Nancy »
Jim,
This is very useful information - thank you! We don't have any cracks as wide as 1/2", but some of them are very long - I'm guessing up to 18" without actually going to the boat and looking again. I'd say this will be Thursday's project (next sunny day).
I guess if you used 5200 on the screws, you're not ever planning to remove them again, right? :D
Nancy
