cutlass bearing
kickervr15s@aol.com
cutlass bearing
Post by kickervr15s@aol.com »
i have a question will a worn cutlass bearing make my boat vibrate has new prop and shaft
rbcool
Post by rbcool »
I've seen it happen. But if you have a new shaft, maybe thet didn't line things up properly.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
kickervr15s@aol.com
it does have about 1/4 inch of play in it
rbcool
Post by rbcool »
gezzzzzzzz....... I think you've answered your own question :wink: :wink:
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Will deffinately cause a vibration. Stick in a new bearing, make sure it goes through the center of the stern tube, then check alignment.
kickervr15s@aol.com wrote:it does have about 1/4 inch of play in it
1/4" ??? wow , you no longer have any bearing left it needs to be replaced asap be fore you damage the shaft .
kickervr15s@aol.com
sorry my bad my dad says 1/8 inch of play
Still not good
AbsterMcgee
Change It !!
Post by AbsterMcgee »
Just replaced the cutlass in my 30" with the help of the forum.
Very easyily done with the strut removed. What A difference! Also had about an 1/8" wear.
Abster
