Propane tank question....
For those who have a propane stove - on an F32, where do you mount your propane tank, and where do you vent it if in a box?
I guess a corollary question would be where do you route the gas line?
G
G
George P
1978 Trojan F32 "Defiant"
- Commissionpoint
I'm not at all a fan of compressed gas onboard. I think its very dangerous. Thats not what you asked though.
There is a lot of room in the storage area to the left of the stove. (under the sink) Perhaps you can use that area to help run a line. I'm not going to comment on where I think a safe place for an LP tank is. Parking lot of the marina maybe......
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
+1 on thisCommissionpoint wrote:I'm not at all a fan of compressed gas onboard. I think its very dangerous. Thats not what you asked though.
The first thing I'd like to add is that proane is not usually COMPRESSED.
The propane we would be using on a boat is LIQUIFIED PROPANE generally refered to a L.P. gas.
It works because the liquid evaporates in the cylinder creating a head space filled with gas which then comes out of the valve.
There are rules for safe installation and use onboard a vessel and if followed it's a safe fuel. I really don't think it's any worse than having 200+ gallons of gasoline on board.
The only boat we looked at prior to buying our 10 Meter Mid cabin that had propane installed was a Bayliner 3288. The cylinder was in a locker on the bridge with venting that allowed it to "spill over" if it leaked because the propane gas is heavier than air.
This might help with your questions:
http://www.boatus.com/boattech/casey/pr ... ystems.asp
Mike & Cynthia
1990 10 Meter Mid-Cabin
Traverse City, MI
Traverse City, MI
- Stripermann2
I believe the propane for the stove, was the small bottles, which would attach directly to stove. I don't think the set-up was intended for 20lb tanks...
Thanks guys....a couple of points for clarity as I many not have expressed myself well.
I'm aware of the potential dangers, which is partially why I asked the question. Thanks mike for the link - I'd already looked at that and the ABYC standards etc.
My question really was from a practical application in understanding where folks who use it have installed tanks. (BTW- it would be as small a tank as possible likely 5lb) If on the flybridge where and how vented. If in the cockpit, where and how vented and finally even if on the swim platform. I wouldn't have it in the cabin precisely for the safety concerns mentions.
Each of those locations presents different gas line routing options and venting and that was what I was trying to understand.
If at the end of the day it doesn't feel right to me, then I'll forego the propane option. But it does have some great advantages in other areas and I'm just trying to balance the pros/cons with others experience
G
G
George P
where do you put your scuba tanks? Nitrox? just asking.Commissionpoint wrote:I'm not at all a fan of compressed gas onboard. I think its very dangerous. Thats not what you asked though.
Sluggo
87 10 mid cabin
Ohio river
87 10 mid cabin
Ohio river
- Commissionpoint
I don't mind answering. Sorry for the thread pollution though......sluggo wrote: where do you put your scuba tanks? Nitrox? just asking.
I personally don't dive, but if I did I would only worry about the tanks if I had filled them with explosive gas. I am also not on the F-32 superperformance racing team nor do I perform marine dentistry, so similarly I don't have any N2O on board.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
I keep a 5lb tank on the fly bridge. It is only used for my bbq though - it's not plumbed to the boat at all. My spare hose, when coiled up just the right way, makes a nice little 'collar' that the tank sits inside of. All of that is on top of a bit piece fo nonslip so things don't move around. Otherwise the tank is fully exposed to atmosphere for any venting that may occur (I don't think the bridge cover is air tight enough to cause any issues.
I don't see an issue with using propane on board as long as it is a properly installed system. I don't see it as being any worse than having a source of spark (distributor) just inches away from a carb with a vented bowl of fuel. I think the wiring I see on some boats is more dangerous!
Big D wrote:I don't see an issue with using propane on board as long as it is a properly installed system. I don't see it as being any worse than having a source of spark (distributor) just inches away from a carb with a vented bowl of fuel. I think the wiring I see on some boats is more dangerous!
+1 and no one seems to have issues with smoking or candles, i plan on propane or at least a bigger butane cook top
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
George
This was a stock option that Trojan used in 1978. It is on the fly bridge. As you can see the fiberglass box is located just to the right of the starboard seat. As far as venting there is none as a matter of fact Trojan made the box as air tight as possible. The tank is a horizonal tank about three gallons, The gas lines are copper and are ran in the wire chase between the side windows. There is a electronic valve that shuts the gas off at the tank that is controlled by a 12 volt switch located next to the stove. This prevents the possibility of gas leaking into the cabin when not in use. The systems seem to work very well.
http://i1123.photobucket.com/albums/l55 ... 0_1366.jpg
1978 F-32 Knotty Playsure twin 350xl 270 Crusaders
EDMONDS WA
Teach a boy to fish and he will go hungry supporting his boat
http://s1123.photobucket.com/albums/l550/Larrys78/
larrys@wsconline.net
EDMONDS WA
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
Propane is common on sailboats . All the sailboats I have seen that use propane have a locker for the tanks . the locker is set up so if the tank leaks the propane will vent out side the hull ( vents at the bottom of the locker) . Propane is heavier then air and can settle in the bottom of the hull .
There have been boats blown up due to propane , so you need to be careful and do it right. And yes you can say the same for gasoline .
Myself ? I would not have it or candles for that matter
smoking ? back deck at 20+ knots only
