1971 F-26 Repower Diesel or Gas?
wolfnnj
Re: 1971 F-26 Repower Diesel or Gas?
Post by wolfnnj »
Yes it's an HEI from AAA marine supply
Big D wrote:Looks great. Don't know if anybody has already asked but is that a "marine" distributor shown in the picture?
1971 F-26 w/ 350 Crusader and Paragon PV-31 V-drive.
1968 MFG Westfield w/ Evinrude 50
Just an idea for the dipstick ------ cut off what you need for clearance with a tubing cutter then cut the same amount from the end of the dipstick itself---double check on oil fill and you are done---hope this helps , Mike
wolfnnj wrote:Yes it's an HEI from AAA marine supply
Thanks for the heads-up. 'bout time somebody converted them for marine use. Good design.
X2
wolfnnj
Post by wolfnnj »
Does anyone have a PDF of the electrical diagrams in this year range F-26? :?:
The Dog House
Post by The Dog House »
wolfnnj wrote:Does anyone have a PDF of the electrical diagrams in this year range F-26? :?:
Email sent. I couldn't attach a pdf to this post. If other people are interested, I'll put it up on photobucket and post it.
wolfnnj
Post by wolfnnj »
well a minor set back I put oil in the new engine and at about 4 quarts it peed on my leg :( Turns out the timing chain cover had a welded piece on it and the weld broke......Chinese peice of &^^(*%$^& that being said I took the entire front end and bottom end apart and redid it all over. I should say here and now I HATE doing things twice! So now all back together again and off of the engine stand waiting to be wired and started. :lol:
Here are some more progress photos.
Ol Dash
new dash
wolfnnj
Post by wolfnnj »
I just had to post this one
http://cgi.ebay.com/ebaymotors/F25-TROJ ... 1c314eaf9a
A trojan f-25 with a 454 engine WT ??? :?: :?: :?
wolfnnj wrote:I just had to post this one
Roy on this site had one . And no Trojan did not put them in
The Dog House
I wonder what transmission he has it mated to? I don't think the standard Paragon V drive would handle a 454 very well.
The Dog House
I noticed on your new instrument panel you have two fuel gauges. My boat had two non-working fuel gauges when I bought it. I replaced them with American Standard Faria fuel gauges (Empty = 240 ohms, Full = 33.5 ohms) and now they read 1/4 F when full and F when they have 8 gallons remaining (they go backwards). Assuming linear resistance change (I know, probably not completely accurate), 1/4 F (full) would equal 188 ohms. I'm going to install European Standard Faria fuel gauges this Summer (Empty = 10 ohms, Full = 180 ohms). Hopefully this will get my fuel gauges working close to correctly (I'm not expecting perfect). I'll let everyone know once I find out. Make sure to take into account the resistance of the senders and the circuit wiring (parallel vs. serial) when changing to two gauges.
wolfnnj
Post by wolfnnj »
I have new tanks and new sending units :)
Its not a v-drive . On you gages just get matching senders or gages that match yours
The Dog House
prowlersfish wrote:On you gages just get matching senders or gages that match yours
There seems to be uncertainty regarding what the ohm values of the original sending units were. There also seems to have been a change when a PO went from one fuel gauge to two. I'm not sure if this is a parallel circuit vs serial circuit issue or not. Changing the gauges is a lot easier than changing the fuel senders. If the European Standard gauges don't work, I'll need to eventually replace the senders. I'm hoping the European Standard gauges work like I expect them to. Changing the fuel senders will be a real pain in the a$$.
Interesting , you can always check the sender with a ohm meter ( gage disconnected ). You said the PO when from 1 gage to 2 ? That could be the issue .Duel gages take different senders Do you have a Fly bridge ? Take one gage out of the circuit at a time and see what happens .
