F-26 Deck Repair
Re: F-26 Deck Repair
Thanks guys! She's getting there
Aaron,
All of my chrome plating was done by New England Chrome, they did a really nice job. They are located in East Hartford CT.
Matt
Aaron,
Matt
Here are some more progress photos, just before I threw the cover on. Still have some blocking needed around the cockpit area, and to roll on the non-skid when it gets warmer but it's pretty close. I still have a whole laundry list of things to do, until then I'm going to start putting the cabin back together until the weather gets warmer. Before I throw the headliner up, I'm going to run new wires for the cabin lights, horn and Nav Lights to make life easier in preparation for next year's project.
Nice job Matt! Is that paint as sprayed or has it been polished? Beautiful shine.
Nice
Thank You
The whole boat was sprayed from the rubrail up with Gel-Coat, The photo's show the initial buff after wet sanding. All that's left is fix a few spots, then roll on the gel coat non-skid in the spring
That looks great! This makes me want to tackle some of this on my own F-26. Too bad it's -15F and -36 wind chills up here by Superior
Sincerely,
Redfin
1978 Trojan F-26 HT Exp
1978 Sea Ray SRV 240 HT
1981 Whaler 18 O/R
1967 O'Day Seven-Eleven
Redfin
1981 Whaler 18 O/R
Looks beautiful Matt. She is a lady with her youth back!!
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
Looks great
That turned out really well Matt. I like the plate that you used under the roller pivot. What did you use under the deck for a backer?
Thanks guys.
Matt
Paul, I have a similar stainless bracket underneath. I wanted to spread the load a little. Thanks again for all of your help, I really appreciated it.Paul wrote:That turned out really well Matt. I like the plate that you used under the roller pivot. What did you use under the deck for a backer?
Matt
- 32pacemaker
Matt the new decks look fantastic!! is the texture the same as the stock texture ?
Thanks Roger, the non skid was put on with a roller, and doesn't match the original texture. From my limited time on the new deck, it does have more grip,especially when wet. The original was worn pretty smooth. When I get down to the boat I will get a photo of the new texture. I still have a lot of little loose ends to tie up, but it is more enjoyable working on it in the water
- gordd
- Sporadic User
]Nice job Matt , was one of first things I had done but just half forward deck and half mid deck. cpl years sitting rest of decks tthat wasn't done got worse so have to do those eventually. Very top cover is totally soaked according to moisture meter will need to replace it or maybe even try going with out it . not sure yet
Looks like are boats are very similar but they call mine f 25 lol
Wow. Wow. Wow. Is all i have to say. I have f32 with a soft bow. I was hoping to try and fix it from below to not have to cut out the top. Has anyone ever tried to do that b4? Or am I wasting my time doing it that way?
1974 f32 Sedan
Twin 233 Mercruisers
