INSTANT FUN REPOWER IN PROGRESS
DAVIDLOFLAND
Re: INSTANT FUN REPOWER IN PROGRESS
Post by DAVIDLOFLAND »
Day 14 - Tanks and exhaust back in, cockpit deck back down, fuel manifolds in.
Fuel manifolds
Fuel manifolds
Day 14.jpg (55.17 KiB) Viewed 8948 times
Yanmar 6BY3-260's
Nice Job !
yorklyn
Post by yorklyn »
very nice!
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
adrewoh
Post by adrewoh »
Looks great!!
marklo154
Post by marklo154 »
I have to do something similar to your fuel manifolds, I was wondering what make they are and where you sourced them from. Also how many tanks are you running ?
1978 Trojan F36 Tri Cabin
marklo154 wrote:I have to do something similar to your fuel manifolds, I was wondering what make they are and where you sourced them from. Also how many tanks are you running ?
That set up looks like it for 2 tanks , remember diesels also have return lines .
DAVIDLOFLAND
It is indeed a two tank, two engine diesel system, hence the return lines. The manifolds allow running either or both engines on either tank, and you can transfer fuel from one tank to the other if needed.
The make is DIY. It does take some figuring to assemble. My supply lines are 3/8" from the tanks to the filters, then 5/16" after the filters to the engines, then 1/2" returns.
Yanmar 6BY3-260's
Your returns are larger then then the supply lines ?
DAVIDLOFLAND
Yep. Don't ask me why. Yanmar thing.
Yanmar 6BY3-260's
DAVIDLOFLAND
Lower complete (5).jpg (48.66 KiB) Viewed 8791 times
Lower helm is done and wiring harnesses installed. New 12V wiring in the engine room, then start fitting the engines. Like Lorena Bobbit said, "It won't be long now".
Yanmar 6BY3-260's
Post by Paul »
Sweet! What type of wood and finish did you use?
DAVIDLOFLAND
Lower complete.jpg (50.79 KiB) Viewed 8781 times
It's Plexiglas. I went to a fabric store and picked a fabric that was close to the interior wood finish, then sanded 1/4" Plexiglas with 100 grit, then stuck the fabric to the Plexiglas with polyester resin. Makes a cool effect.
Yanmar 6BY3-260's
yorklyn
Post by yorklyn »
That was a great idea! looks awesome!
Todd Pote
Double Pote-N_Sea
DAVIDLOFLAND
Electrical panel complete. Dropped in the first engine and it fit like a glove. No modifications necessary. WOO-HOO!
NOT SPRING YET
NOT SPRING YET
APRIL 10 (2).jpg (41.36 KiB) Viewed 8668 times
PERFECT FIT
PERFECT FIT
APRIL 12 (10).jpg (59.92 KiB) Viewed 8668 times
ELECTRICAL PANEL
ELECTRICAL PANEL
APRIL 12 (2).jpg (63.99 KiB) Viewed 8668 times
Yanmar 6BY3-260's
adrewoh
Post by adrewoh »
Great job, really sharp lower station! The plexiglass was a great idea--nice work!
