13 meter upgrades
The Dog House
Re: 13 meter upgrades
Post by The Dog House »
Captain Chill wrote:What in the hell... Looks like I have 100sq' to cover.
Went to the website to order 3 rolls of the 2'x72'x54.
Price comes out to $643.50. Pricey but I can live with it.
Put in my CA shipping zip code and BAM $897.00 to ship!!! Are they out of their mind?!? It's foam, I mean come on.
Do they not sell this anywhere else? Any advice DOUGNASH?
I used Dynamat Hoodliner in my engine compartment and it reduced the noise significantly ( http://www.amazon.com/Dynamat-11905-Hoo ... B00069QLVC ). It has adhesive backing which worked well. Just make sure to degrease thoroughly before applying.
Captain Chill
Post by Captain Chill »
The Dog House wrote:I used Dynamat Hoodliner in my engine compartment and it reduced the noise significantly It has adhesive backing which worked well.
Pricey as well. But it's a proven brand-name for sure. Says to use Dynamax Xtreme and then the hoodliner for best results. Did you do the whole cockpit floor or just above the engine. I'd love to see some pictures if you have them handy.
'The Pacific Chill' - F26 -1976
Captain Chill
Going with the Dynamat Xtreme under the cockpit and on the side walls.
Putting the Dynamat Hoodliner over the Xtreme on the hatch directly over the engine.
Will post results in my restoration journal. Thanks.
DOUGNASH
Post by DOUGNASH »
Glad to see the forum is back on line
DOUGNASH
Post by DOUGNASH »
Spent last weekend working on the exhaust
Took all weekend to polish these up
DOUGNASH
Post by DOUGNASH »
Exhaust is now hooked up from turbos to mufflers
Also connected the throttle, gear, and emergency shut-off cables
this will be sweet when done.
What kind of performance difference do you anticipate over the former engines?
Look'n good . Not trying being to be negative , but did you inspect the exhaust inside ? The reason I bring it up is the way its designed any leaking inside will get to the turbo(s) when shut down ,possibly worse . Just something to look out for as I would hate for you to have a issue after all this work .
Captain Chill
:shock: Hell ya. This looks way future. Nice one.
DOUGNASH
Post by DOUGNASH »
RWS wrote:this will be sweet when done.
Well the 671's were rated at 450hp each but they were definitely not firing on all cylinders
These 871's are rated at 462hp
If I could get to a 18-20 knot cruise @ 1900rpm's I will be very happy
They should reach 2350rpm under load, so we will see what happens, I might have to re-pitch the props
My friend owns a prop shop, he was already totally disappointed I didn't have to spend big bucks on new shafts, I wasn't though lol
DOUGNASH
Post by DOUGNASH »
prowlersfish wrote:Look'n good . Not trying being to be negative , but did you inspect the exhaust inside ? The reason I bring it up is the way its designed any leaking inside will get to the turbo(s) when shut down ,possibly worse . Just something to look out for as I would hate for you to have a issue after all this work .
I have been thinking about this a lot
It's definitely a bad design
There are plugs on the bottom to drain out any water
I will at least change the plugs with ball valves to make them easy to drain
I also thought about putting a 12volt solenoid to the drain connected to the ignition, when the ignition is on and the motors are running, the solenoids will close, when power is off, they would open to drain any water
DOUGNASH
Post by DOUGNASH »
Captain Chill wrote::shock: Hell ya. This looks way future. Nice one.
Im taking it back, way back with these 2 stroke diesels
More like "old school" than future :mrgreen:
DOUGNASH
Post by DOUGNASH »
Spent another full day on these motors
I put the intercooler back on and connected all the pipes for the cooling system
Also put in new thermostats
I have to pick up a few more hose clamps to finish
Barrie
Post by Barrie »
Those diesels are way cool
Something very "steampunk" about the copper exhaust :)
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
gardnersf
Post by gardnersf »
Hi Doug. Any Updates?
