Stuffing Box Packing
fourreins
Post by fourreins »
Need to repack and was considering Gore GFO, but have read about some concerns about galvanic corrosion. Is this really something to worry about? What are most people using today?
2020 Gold Support
2020 Gold Support
Re: Stuffing Box Packing
That's what I have been using I had any issues .
TROJAN F36 Conv.
2009 TROJAN RENDEZVOUS
Allen Sr
Post by Allen Sr »
That's what I used when I did mine 5 years ago with no issues.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
The Dog House
Post by The Dog House »
I used Gore GFO packing 3 years ago and have had no issues. I have read that other similar products are not as good and to make sure to use the Gore brand. I think it cost me $9.00 for the Gore, so there isn't any reason to use the cheap stuff.
http://s1263.photobucket.com/albums/ii624/clastewart/
bjanakos
Post by bjanakos »
Where did you source it? What size for an F-32? I need to get mine done as well.
2020 Gold Support
2020 Gold Support
West marine and others carry it . The size varies on your shaft size F32s use several deferent size shafts .
What size is your shaft ? I have a chart ( That I have posted several times )
TROJAN F36 Conv.
gitchisum
Post by gitchisum »
What would a 1.25" shaft need Paul?
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
2020 Gold Support
2020 Gold Support
1/4"
1" uses 1/4" packing
1 1/8" shaft uses 3/16" packing
1 1/4" shaft uses 1/4" packing
1 3/8" shaft uses 5/16" packing
1 1/2" shaft uses 1/4" packing
1 3/4" shaft uses 1/2" packing
2" shaft uses 3/8" packing
2 1/4" shaft uses 7/16" packing
2 1/2" shaft uses 5/16" packing
3" shaft uses 9/16" packing
TROJAN F36 Conv.
Reel Easy
Post by Reel Easy »
How much do you let this type drip? Or how tight do you Tighten it?
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
2020 Gold Support
2020 Gold Support
Reel Easy wrote:How much do you let this type drip? Or how tight do you Tighten it?
The official rule "loose enough to allow lubrication and keep the gland from overheating, but tight enough to minimize flow". That can vary from boat to boat from 1-2 drips (or less) / minute at rest, to 6 -10 drips (or more) / minute. What's great about the Gore GFO is the PTFE in it is so slippery that it lets you crank it a bit tighter without generating a lot of extra heat from friction.
I picked up an infrared thermometer (http://www.amazon.ca/General-Tools-Inst ... B00377BSU4), and after setting up stuffing boxes the way I think they should be, I aim that at the boxes while under way to check on temps. Its easier (and safer) to use an IR thermometer to find out what's going on, than to put your hand on a potentially 200F piece of brass! I am sure temps will depend to a degree on what water you are operating in (Florida and Alaska might be a tad different!!), but temps under 120F are probably safe. That's colder than the temps your T-Stats will open at. If you can run at <120F and have minimal drip rate / spray at running speed, and 0-2 drips at rest, you are doing good.
Other things can affect it too. For a couple of years I had an annoying as heck squeal from one stuffing box shortly after shifting from forward (at idle) to neutral (once the boat slowed down a bit the drag on the prop forced the shaft to turn at a speed that hit some resonance frequency). And I had a bugger of a time controlling temperatures. At one point I had a pretty good trickle of water coming in at 2500RPM (more of a spray at that RPM), so tightened it 1/4 turn. Checked it 5 minutes later, and there was STEAM coming off of the gland!!! Eventually found that (somehow??) the packing nut had been cross threaded, and it was just friction between shaft and nut... once nut was properly aligned and seated, I could get away with 1-2 drips per minute (or even dryer) when docked, and at speed the gland was only hitting about 90F.
RonW
Post by RonW »
Thank you Prowlersfish for the packing size chart.
I'm new to stuffing boxes and didn't know the little fellows were so fussy. Having cruised this forum, when I first joined, I figured that I'd better learn and pay attention. I found mine to be in excellent shape based on what I've read, but I also now feel that I know how to monitor, adjust and maintain them.... thanks to all of you guys.
(so glad to be finished with stern drives)
Ron
K4282
Post by K4282 »
looks like you got the information you were looking for, just to reiterate I also and using Gore GFO and not having any issues with two different F32s, the older one I replaced the packing 4 years ago, super cheap, i mean under $10 shipped to your house to do both shafts, sourced from a google search
Reel Easy
Post by Reel Easy »
Thanks guys.
Dustin
Christian
Post by Christian »
Hi Prowlerfish,
Does the list of sizes you kindly posted apply for the rudder stuffing as well?
Cheers,
CB
2020 Gold Support
2020 Gold Support
Yes
TROJAN F36 Conv.
