Stewart Warner Guages
Svend
Post by Svend »
I am putting 2 new stewart warner temp gauges in my 77 f30 with 318’s that i got on Amazon
https://www.amazon.com/gp/product/B002F ... UTF8&psc=1
what temperature sensors should i get for block to send electric signal up to new gauges? i know senders should match gauges
thanks!!
happy 4th!!
Raymarine EV 100 Auto Pilot
Re: Stewart Warner Guages
Look up your gauges p/n and it should list the proper sender . The paper work with the gauges should also list the sender range .
They list the temp senders on your Amazon link also
Trojan always used 1/2 NPT best to check the size which you can not do with a ruler. take it to a hardware store and check size with female fitting.
