New Owner, '69 Hardtop Express Cruiser, Anybody have info?
Just pick up a 1969 hardtop express cruiser. She's been neglected for the last 12-16 years, sitting in the middle of the desert. Any info that anyone has on this boat would be appreciated.
Thanks,
Mike Speck
Thanks,
Mike Speck
I agree that the hull and stringers should be in good shape, but from the looks of it you have a heap of work on the topsides. Deck core rot may not be an issue due to either desert storage or the deck is all teak on that year Trojan. Engine and tranny may require rebuild (seals at least) after all those years of non-use, and the desert heat is going to be no friend to rubber seals, gaskets, etc. Take it one project at a time. My suggestion is to start at the bottom and work your way up....bottom, hull, driveshaft, tranny, engine, cockpit, cabin, deck.....and all the goodies along the way that you encounter - electrical, plumbing, etc .....again, most likely compromised by the desert heat. What the hell, it'll keep you occupied and out of trouble!
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Unfortunately, much of the exterior wood was ply and turned to crap, even the teak on the exterior has dried out so much that the larger pieces have split apart. Most of the interior is salvagable. We plan to tear her apart and rebuild using basically the same lines with some minor modifications. She will be rebuilt with epoxy encapsulated marine ply. As for the engine, is has been out of the boat for at least ten years, the only salvagable part is the block and it is the 195 horse 273 so I think we will end up dropping a 305 in her. The original velvet drive looks good from the outside, haven't torn it down yet. Stringers looks good, but the upright supports at the stern with have to be replaced. So far we have torn off the cockpit deck and supporting structure.
Mike
Mike
middle of the desert ?
Why do boats end up in the middle of the desert ? I have seen this many times .
