Prop size- F36
Prop size- F36
My good friend has a 81-82 F36 Sedan, 460 Fords.
What is the correct size prop for this boat? He now has 21x22 on since he's had the boat. Something says it's not the right size... :?:
Thanks for your input, I'll pass along the info to him.
rossjo
Post by rossjo »
Sounds reasonable for 460 big blocks ... depend son transmissions gear ratios ... why do you ask?
Thanks Ross,
The reason for the question was that although his boat runs very well, bottom is clean and no other performance issues, he cannot attain a rpm over 3400. After speaking with another friend of ours who has an F36 with 440's in it and runs 20x19 props, the question arose that maybe he was over-propped.
A friend had one with 454 and it ran 20x19 I belive . I and runing 22X22 but I have diesels And I know there bigger then another f36 that was hauled out next to me .(w/440)
Running 454's with 22x22 = 27knt on a 36'
rossjo
Post by rossjo »
What transmission gear ratio? Without that, we're comparing apples and oranges here.
true I'll look tomorrow
No matter what the gear is this boat is over proped by the rpm readings . the 460 was the replacement for the 440 . I would check the tachs make sure they are right first ,
Not sure of the gear ratio. Thanks, guys...I'll pass the info along.
alexander38 wrote:Running 454's with 22x22 = 27knt on a 36'
Thats not on a F36 Is it ? I belive they came with 20" wheels .
You know it's not.. :wink:
gjrylands
Post by gjrylands »
My F36 has 20x21 props with 1 3/8 shafts. Chrysler 440 engines with 1.91:1 Velvet drive trans & reduction gear. This was the stock setup in '79
Gerry
1979 F36 Twin Chryler 440's
