Rudder play on F-32 1978
- TADTOOMUCH
When I hauled out for the winter I noticed that my starboard rudder has about 3/16" of play in it and the port one is nice and has no play. They both rotate fine and the starboard one leaks a little more than the port did. Is this just a packing issue or do I have a bigger problem that needs more work? Has anyone removed their rudder and replaced the bushing. Not sure how the whole rudder bushing assembly is made. Can anyone give me a description of the assembly and what might need replacement/
Boat Name: A TAD TOO MUCH
I have nothing to offer but a bump
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
- TADTOOMUCH
Rudder Play
The play is side to side. Up and down there is no play at all.
I'm sure the side to side play is probably a bad thing and will be harder and more expensive to fix than the up and down would be if things go for me the way they usually do.
- TADTOOMUCH
Great!
Rossjo,
That is exactly what I needed to see. My guess is that the key on the shaft has worn or the top bearing has worn out. I doubt the packing being bad or the nut being too loose would allow that much play. Now that I have a good diagram, I can take it apart and find the culprit.
Tad2 ....
What was the outcome on your rudder? I have some play in mine, and would like to know how yours came out before I tackle repacking/repairs.
Thanks you in advance, Ross
- TADTOOMUCH
Rudder play
Got lots of stuff to work on so the rudder will be spring project
- TADTOOMUCH
Rudder Play
I found out my rudder is not loose in the packing or shaft bearing. It is loose where the rudder attaches to the shaft. Both rudders have about 1/16 to 3/16" of play in them where they attach to the shaft. Is this normal or from wear? How are the rudders held on to the shaft?
