outrigger mounting
chauzer
outrigger mounting
Post by chauzer »
i bought a set of used rupp single spreader outriggers with the bigger tri-pod mounts and what i'm wondering is when i bolt them onto the boat should i use some kind of backing plate on the mounting bolts? i would hate to stress crack the fibergalss.
life is tough! it's even tougher if your stupid.
~john wayne~
ready123
Post by ready123 »
I would... the size required depends on where you put it. Where are you planning to locate it, Aft rail?
Yes you should use backing wood block will work.
Ready I don't think you can mount those on a rail
http://www.ruppmarine.com/Ruppriggers/T ... ers-8.html
You can set the set mounted on my photo (Lees Jr)
chauzer
Post by chauzer »
thanks! it would make sense to do that. now, what do i use to clean off all the saltwater stains? i have a demel tool and a buffing wheel with rubbing compound but its going to take forever. is there anything that works better? it's gotta be a nightmare for you saltwater guys keeping all your fishing gear and stainless steel salt free!
~john wayne~
Its not that bad , soap and water /hose and go / and wait till it rains when the water iscut off do to low temps. Rupp Auma guard is good stuff to use , but it is very slippery ( don't use on hand rails or you could slip)
http://www.ruppmarine.com/Accessories-A ... d-c36.html
