I talk to the guy that used to own my boat number of years ago. He stated with that 16x18 LH prop, He was getting 4500 rpm`s so he said one time that he only got 3100 like I am getting now. He said it was carburetor issue so I will be looking into getting a new carburetor soon.
BTW he said he missed the boat dearly was it for sale? I said NO NO NO NO
Talk to SEAYEA
Talk to SEAYEA
Trojan
earlier i mentioned the distributor advance. i never saw whether you addressed this. have you verified the advance is working? i do know that was my problem. would like to know.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
If you have a 1 to 1 ratio there is no way you could turn a 16x18 prop . Also if you could turn a 16x18 you could break a shaft thats a lot of prop for a 1" shaft
First get a photo or lazer tach and check you engine tach to see if its right .
Second use the the photo/lazer tach to check the shaft rpm vs the engine rpm .
Untill you know what you have you just going to throw money away and never have it running right . untill you know every thing is a guess
I know your gear is suposed to be a p31 1 to 1 but someone may have chaged the gears in side
