props for my f-32
f-32
props for my f-32
Post by f-32 »
hello!!! I bay a trojan f-32 1975 with twin caterpillar 3208 natural aspiration of 210 HP with boxes twin disc 502 1.54: 1 in perfect conditions, but it does not have props, i would to know what props I must use to reach a good speed 18 or 19 cruise and 22 or 23 max. thank you!!!!
i from venezuela, excuse for my English is very bad...
my boat is like this: http://www.yachtworld.com/core/listing/ ... =1821&url=
jav
Post by jav »
I've seen the boat and it had props when I saw it. What happened to the props? I have a spare set from my f-32 twin diesel (200 hp) but I'm not sure they'll work with the 3208 since the RPM is different.
f-32
Post by f-32 »
jav wrote:I've seen the boat and it had props when I saw it. What happened to the props? I have a spare set from my f-32 twin diesel (200 hp) but I'm not sure they'll work with the 3208 since the RPM is different.
Hello jav my props was robbed for that reason it is that I do not have the step nor the single diameter. i memory that was of 4 blades. In any case thanks for your aid!!!. Equal if you can tell me the data of your props, in order to see if similar ones can do me, the cat 3208 work in load to 2800 max rpm. whichever knots cruise and max reach your boat whit 200hp?
excuse my English again... THANKS!!!!
ROMMEL.
jav
Post by jav »
Rommel,
My spare props are 16" diameter with 15" pitch - no cup -3 blade. My new props are 17" diameter 14" pitch with medium cup. My engines are 3800 RPM Max and I also have 1.51 : 1 gears. My boat cruises at 20-21 knots at around 3400 RPM and tops out at 24 knots at 3800-3850.
Your boat maybe slower since the Cat 3208 is a heavy engine - mine are volvo 6 cylinder turbo diesels. If I recall correctly, the previous owner was claiming a cruise speed of around 17-18 knots. Did you buy the boat from Jay over at south shore?
rossjo
SO
Post by rossjo »
So, someone finally bought the pretty Blue F32! Congrats - CAT-3208s are very nice. You can add Turbos for another 50-75HP each with no issues of overloading them.
I have a pair of Cummins 6BTA 220HP engines, 1:1 Velvet Drives. I'm playing with 17x20's now - but they're a bit over-pitched (except when I'm runninglight and down seas!).
Do you have stock struts and 1.25" shafts?
If so - these are the limiting factor. You're limited to 17" diamater - and will need about 22" of ptich to work with the 2500RPM(?) and 1.54:1 trannys. This is a lot of tourque on a 1.25" shaft ... but will work if you can find a prop with this dimensions. a 4-blade might be best, but 3 is generally faster ...
Join http://www.BOATDIESEL.com a($25/year) and use their PropCalculator. If I find time, I'll run your numbers.
jav
Post by jav »
it would seem that I misread the original post. The gentleman says his boat is "LIKE" the one in the link. I just emailed the broker and the blue F-32 in massachusetts remains 'available'.
f-32
Post by f-32 »
jav wrote:it would seem that I misread the original post. The gentleman says his boat is "LIKE" the one in the link. I just emailed the broker and the blue F-32 in massachusetts remains 'available'.
Hello jav! it has badly understood my boat is “like” the one of the Link that associate sends excuse me!!!. I live and my boat is in Venezuela! I was writing broker for to facilitate me the information of props but not answer me… shipment photos so that they see my boat them, my boat is in very good conditions, but some trief had stoled my prop… I also thank for the information that I provide to the friend rossjo! Jav if you can obtain me the props information whit the broker will be Serious helpful for my!!!
THANKS FRIEND!!!
ROMMEL
jav
Post by jav »
Jason told me he was going to try to look at the props on his boat when it comes out of the water but he's not sure when that will be.
I ran a few calculations on your boat. My boat performs somewhere between an average and slow planning boat. I used a weght of 17500 pouinds for yours becuase the 3208 is heavy. The calculator recommended props as follows:
17" diameter x 20.5" pitch with medium cup - 4 blades.
this should produce a cruise speed of around 19 knots and a top speed of around 21-22 knots.
THIS IS ONLY AN ESTIMATE!!!!!! NO GAURANTEES THIS WILL WORK AS I"M NOT A PROP EXPERT.
rossjo
prop calcs from www.BOATDIESEL.com
Post by rossjo »
Trojan F32, 15,000lbs, 30ft waterline-length, Avg Planing hull
2x210HP engines, 1.54:1 transmission, cupped props
Here are the calculations from http://www.BOATDIESEL.com ($25/year):
They recommend a 22" dia, but you are limited to 17" on the F32 (with stock struts/shafts), so:the recommended props are:
> 3-blade = 17x26 cupped = 22knot max @ 25gph, 16knot cruise@ 13gph
> 4-blade = 17x24 cupped = 22knot max @ 25gph, 16knot cruise@ 13gph
My recommendationis the 3-blade, so you'll pane out faster. I'd also consider a set of aftercooled turbos
____________________________________________________________
3-blade cupped prop:
MAX PERFORMANCE
Available Power: 407.4 SAE hp ( 303.8 kW) @ 2500 RPM
Max Speed: 22.2 kts
Fuel: 25 US Gall/Hr (typical)
CRUISING PERFORMANCE
Cruising Power: 223 SAE hp ( 166.3 kW) @ 2000 RPM
Cruising Speed: 16.5 kts
Fuel: 13 US Gall/Hr (typical)
RECOMMENDED PROPELLER
Diameter: 21.6 in. Pitch: 20.8 in.
Blades: 3 Cupped: Yes
Transmission Ratio Acceptable
PROPELLER BASED ON INPUT DIAMETER
Diameter: 17.0
Pitch: 26.3
Blades: 3
4-bladed cupped prop
MAX PERFORMANCE
Max Speed: 22.2 kts
Diameter: 20.3 in. Pitch: 20.4 in.
Blades: 4 Cupped: Yes
Diameter: 17.0
Pitch: 24.4
Blades: 4
rossjo
Pair 17x21s
Post by rossjo »
Here is a pair of 17x21, 1.25" shaft Brass props on eBay - current bid = $779.95USD.
The seller has 99.5% rating on 3118 sales.
BUY THESE and let's go fishing! I'll come down and catch some Sailfish with you!
"PAIR OF 17 X 21 BRASS PROPS RH & LH"
http://cgi.ebay.com/ebaymotors/ws/eBayI ... B:EF:US:11
or
http://cgi.ebay.com/ebaymotors/PAIR-OF- ... enameZWDVW
eBay ad ...
You are bidding on a PAIR OF 17 X 21 BRASS PROPS RH & LH
Auction Details:
* Brass Prop #1
o Bore: 3cm / 1 3/16" - 3.5 cm / 1 3/8"
o 17 x 21
o LH
* Brass Prop #2
o Bore: 2.8 cm / 1 1/8" - 3.5cm / 1 5/16"
o 17 x 21
o RH
Condition:
This lot is in fair cosmetic condition. Please see all images prior to bidding. This auction is rated a 6.5 out of 10 for its cosmetic condition.
Please see our eBay store for more props & boat parts.
Bid Now!
JK
ISI Number: 101210008105
f-32
Re: Pair 17x21s
Post by f-32 »
rossjo wrote:Here is a pair of 17x21, 1.25" shaft Brass props on eBay - current bid = $779.95USD.
or
eBay ad ...
Auction Details:
* Brass Prop #1
o 17 x 21
o LH
* Brass Prop #2
o 17 x 21
o RH
Condition:
Bid Now!
JK
ok buddies! Thanks for all your advises then. I'll try with the dimensions you provided me and I'll tell you later what hapenned... Otherwise, if you can find the blue f-32 dimensions from the broker you met, i would really apreciate your help again. Hope to catch up with you sailing someday here in Venezuela! Good fishing and good babes too!!! bye bye
rossjo
Good Sailing & Babes?
Post by rossjo »
Good Sailing AND Good Babes?
I'm definiteyly loking forward to fishing on your boat in Venezuala. What port are you in ?
Whats your name, boat name & contact info?
We may be down this winter for some sailfish!
like capt Ross saysjoin boatdiesel.com best 25 bucks you will spend !
Ross did you mean to do the prop cal. at 2500 ? I belive the rated rpm is 2800 ( not max) corect me if I am wrong
That blue 32 is one nice looking boat I like what he did with the door
I would love to do that to my 36
rossjo
Post by rossjo »
Paul - yes ... that Blue F36 with the custom back door looks great (in the pix). I am considering a weight reduction on my F32 (already removed inside doors), including Lexan Margard side windows and a similar look for the rear - but who knows?
The Cat 3208s spin to 2800? I didn't look them up, so my error! Will the 3208s spin 2800-3000RPM w/o Turbos?
HEY - VENEZUUALA - join http://www.BOATDIESEL.com & run your calc's @ 2800 RPM, 2x210HP with 17 x 24 3-bladed props (?) and let us know what you think ...
Paul and I will come down to Venezuala in Januuary to see how the boat (and babes) run!
Ha!
Thanks for the feedback Paul! Wht props do you run on your boat with a pair of 300HP 6BTAs? Do you have stock struts/shafts?
Ross got the 2800 rpm off f32s 3rd post maybe he can tell us if this is the rated rpm ( you may be correct ) I may go to http://www.boatdiesel.com to check
I am running 22X22 three blade 1.53 gear and 1.5 shaft
