F 36 STRUTS
Buckknekkid
F 36 STRUTS
Post by Buckknekkid »
Anyone know a good supplier.. or welder
F36 ~
SHES SOLDDDDDD
can't Bob get them ?
Buckknekkid
I just emailed them
F36 ~
SHES SOLDDDDDD
jav
Post by jav »
I tried welding mine (f-32) and it would not work due to casting porosity and salt intrusion.
I was able to source new ones from the manufacturer (Buck Algonquin) using the casting number of the side of the strut.
Buckknekkid
I'll try to clean off the anti fouling and find a number
F36 ~
SHES SOLDDDDDD
Buckknekkid
noop ,, it was welded before and its a bad job..
F36 ~
SHES SOLDDDDDD
Buckknekkid
Beacon comes through
One call, hull number and UPS shows up at my door... Thanks to the guys at Beacon ,, Ray
F36 ~
SHES SOLDDDDDD
rossjo
Post by rossjo »
how much?
Buckknekkid
they arent cheap
about $950 each, cutlass bearing included, I posted pics on Boat Design .net
F36 ~
SHES SOLDDDDDD
Buckknekkid
ok click here to view or copy and paste
http://boatdesign.net/forums/showthread ... post140433
notice the size of the 37? Searay beside us. :wink: :wink:
F36 ~
SHES SOLDDDDDD
Buckknekkid
oops a glitch
Width of supports was different so we had to do a little drilliin and fillin ,, check out this thread again for pics
http://boatdesign.net/forums/showthread.php?t=17339
F36 ~
SHES SOLDDDDDD
rossjo
Broken Strut - 1974 F32
Post by rossjo »
My diver showed up today to clean my bottom, and told me I have a broken strut on my 1974 F32.
Where did you guys find one? What Buck Algonquin casting is it? Who do I call @ Beacon marine?
BUCKNEKKID's new strut was a different "trianguluar" design that looks much stronger. Is this available for tehe F32. If so, I'd have to drill new holes, and fill the old (not trivial).
Sounds like I have a lot of work ahead of me. Any other advice?
:( :( :( :( :( :( :( :( :( :( :( :( :oops: :oops: :oops:
Buckknekkid
I have an old one in the back yard,,,, hahahaaa Take a lot of measurements,, width, angle, etc. the strut will give you the same location, comes with a cutlass bearing installed and the angles must match. Location holes dont really matter. Use all new hardware!!!!!
F36 ~
SHES SOLDDDDDD
rossjo
F36 struts
Post by rossjo »
Are these "standard" F36 Struts (pix from Buckknekkid's boat on BoatDesign.net) ?????
http://boatdesign.net/forums/attachment ... 1179357763
mr elevman
Post by mr elevman »
i to this year had found a broken strut port side cracked along the bearring jernal found the casting#and one call to marine tech 2 days latter it was on my door mat when i came home 450$ with a new cuttless and new ss mountting hardware
