blew an engine
blew an engine
Irritating to say the least.
My starboard engine gave up the ghost as we were headed out yesterday. Water has entered the block somehow, and the valve cover vent conveniently dumped all that pretty pancake batter down the intake.
I am going to pull off the manifold, and heads, and find the leak. I am guessing it is either a cracked manifold, blown headgasket, or a cracked head. Dunno at this point. It was too hot to work on it when we pulled into port this afternoon.
Speaking of which, trying to dock her, on one engine, with a strong crosswind, is noooo fun.
'76 F28
sorry to here that....it's all of ours nightmare
Sorry to hear of your bad news.
Once on a return trip an ignition coil failed and we came in on one engine.
Makes you appreciate the width between those props!
Hope you're back on the water soon!
did the engine hydro-lock on you ?
At least the f28 with v drives are fairly easy to pull. The starboard is reverse rotation, I have a 900 hour rev engine if needed. Plus two sets of manifolds with riser, I reused the down turns though.
Larry
Larry
Last edited by larryeddington on Sun Aug 28, 2011 11:46 am, edited 2 times in total.
Update!
Took the manifolds off on Tuesday. I also drained all the oil/water sludge. Brought the manifolds home and filled them with acetone to check for leaks. I didn't see any, but I am not convinced that they are not the culprit for water entry.
Today I went down and stripped the engine to the block. Inboard head was clean, no visible cracks. Outboard head has a burned out/rusted exhaust valve on #2. I am guessing this is where the water was getting into the piston, as there is significant rust on it. No visible cracks in the head. The intake journals looked good as well.
I am on the hunt for a new set of manifolds/risers, as I cannot say for sure which one is the issue. I am going to pick up new gaskets and swap in my spare head tomorrow. No boating this weekend, but hopefully it will be good for next weekend!
'76 F28
Sorry for your troubles. What are intake journals?
If water has gotten into crankcase, it's been my experience that it won't be long before the lower end lets loose. Bearings don't like any water...
