Pulled the Vrive Today OUCH
Sea Ya
Post by Sea Ya »
I pulled the Vdrive out today because it needed repair :)
I nned to fix or get a new one dont you think?
The culprit I think is the lower drain plug...Gone
72 Cutlass Jet 460 Ford (LIKWIDSUKR)
71 TroJan F26 300Hp 351Windsor ( SEA YA )
Agitator
Sea ya
Post by Agitator »
What did you do with your reduction drive? How hard was it to remove?
Mine is cracked on the gear housing and I have it patched right now.
I'll have to remove mine soon.
Sea Ya
Re: Sea ya
Post by Sea Ya »
Agitator wrote:What did you do with your reduction drive? How hard was it to remove?
I tossed it it was trashed. It was not bad. It was real heavy though! Be prepared.
JuiceClark
check...
Post by JuiceClark »
Please check your engine mounts...when they move too much it makes that break you found.
Check this article about a crappy, new Trojan for comparison:
http://www.yachtsurvey.com/boatreviews/ ... xpress.htm
Sea Ya
Re: check...
Post by Sea Ya »
JuiceClark wrote:Please check your engine mounts...when they move too much it makes that break you found.
That it was. The mounts were loose. I filled the holes and I used longer lags.
