F32 SHAFT RPM AT FAST CRUISE
- DAVIDLOFLAND
Before I start researching re-power options, I am figuring paramaters for new engines and tranny's. Forum consensus established that angle change at transmission should be about 10 degrees, for level install of engines.
I want to fast cruise at about 25 knots. Currently, to do that she's turning about 3600 rpm at engine, through 1.5:1 trannys, so assume shaft RPM to be about 2400. Current props are 16 x 18, (which are a little too steep for my current horsepower).
Will need to determine best cruise RPM of new engines, then apply the correct gear ratio to achieve the desired shaft RPM. Then, I can dial in the final package with prop pitch.
So, two questions for F32 owners...
1) Do you agree with 2400 RPM for a 25 knot fast cruise?
2) Do you find the boat seems to get a little 'squirrely' above about 27 knots?
Yanmar 6BY3-260's
Yanmar 6BY3-260's
Join http://BOATDIESEL.COM for a great Prop Calculator that takes water-line length, hull-type, weight, gear-ratio & power into consideration (doesn't matter if its diesel or gas, it goes by HP & RPM). It is very accurate.
My F32 with twin Cummins 6BTA diesels runs 27-28 knots, and is only 'squirrely' in 2'+ following seas (which its 'squirrely' at any speed anyway):
http://rnr-marine.com/Trojan/Viva-Mahia ... 0mar08.MP4
- DAVIDLOFLAND
The boat diesel site is good. Can't remember their site fee though...$25.00 or something around there.
Totally different setup - diesels have a lot of torque, so I'm running a Velvet Drive 1:1. WOT about 2,400 RPM = 27-28knots., so 25 knots is about 2,200-2,300 RPM.DAVIDLOFLAND wrote:Rossjo,
Can you determine your shaft RPM at about 25 knots?
Running 17x20 props. This combo gets great fuel mileage at hull speed. I'm doing about 8 knots at 600RPM idle. Makes for fast docking.
$25/year for BoatDiesel.com - well worth it. The site owner (Tony) is a very knowledgeable diesel & boat mechanic and can answer anything if others don't already have an answer. The Power and Prop calculators alone are worth the $25.
Which brings to light... that this forum is also a great deal at only a $15.00 supportive contribution for all the knowledge, help and insight given each day!
Of course, it's voluntary.
Boatdiesel is a great site and Tony A. is very sharp one of the best on Cummins and Yanmars around. However He is not the ownerof the site . The site is owned by Peter Compton .( Compton marine in St. Tomas VI)
Tony owns seaboard marine in Ca . I get a lot of Cummins parts from Him.
- Commissionpoint
According to my surveyor I am swinging 16x21's. Now, before the peanut gallery goes off its rocker, I don't beleive it either. Either way with the super quick handling around the docks at 650 in gear I feel that probably they aren't the 16x15's I am used to on these F32 hulls. (with gas in the 230-300hp range). Good news is its on the hard for paint, glass and some other BS I wanted to do, so I'll go take a pic or two of the running gear while its in the shop for posterity. Saturday should be good because they won't be spraying and the shop should be mostly idle. I heard this morning that it got moved inside, so it should be only a couple days or so until its done.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
- Struts and Rudders
- DAVIDLOFLAND
Rossjo,
I thin that puts us in the same ballpark at 25 kts. You're 2,200- 2,300 with 17 x 20's. I'm 2400 with a 16 x 18's.
I'm doing the computations for gear ratios, knowing the horsepower needed (approx 300 hp gas), and prop diameter (16"). I intend to check with the engine manufacturer for optimum cruise RPM, then apply gears to achieve a shaft RPM (at optimum engine RPM) in the 2400 range.
Seems to make sense, I think, unless there's something I'm missing.
Yanmar 6BY3-260's
Yanmar 6BY3-260's
Yes, you're probably close, from a shaft RPM & HP perspective. The 1.5 ratio is getting you the torque multiplication on the 300HP to turn that 18p prop ...
BoatDiesel.com will be a great help.
It will actually recommend optimum gear-ratios and diameter for max efficiency/speed.
- DAVIDLOFLAND
