F-32 Shaft Length?
mscho1
F-32 Shaft Length?
Post by mscho1 »
I need to replace my prop shafts. Does anybody know what the length is?? 360s 1977 F32
1977 F-32
I'm sure there is someone here who can help you, they probably just haven't seen this post.
Give Bob a call here at Beacon, he'll be able to give you the measurement.
Or check these guys out, give them a call.
http://buckalgonquin.com/default.html
I would measure what I have , Because if you get the wrong info or if some was change over the years and get the wrong size shaft it will still be your shaft .
mscho1
Post by mscho1 »
Thanks guys, I pulling them out and having them checked. I will post the length here for refference
1977 F-32
