Butyl tape????
Butyl tape????
Anyone use Butyl tape instead of caulk to rebed hardware??? Found some good info online and was thinking about trying it on the bowrail and window frame. Seems to remain flexiable forever and have more elongation than caulk. Any first hand experience???
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
Use it weekly. Ford is big on it since they have bolt in 1/4 glass and use it alot on cargo van glass "fixed glass". Just buy the good stuff. Ours is 3M. I havent seen any leak issues in the past few years. Run your tape and over lap 1/8 inch. Hardware as far as screws and bolts to close the joint? I am going to do that too. Its alot less messy than liquid sealants and should serve the same purpose, cheaper... IMO
captainmaniac wrote:No first hand experience, but know a couple of snailors (spelling on purpose) who have used it to rebed hatches and portholes, and they swear by it.
- ready123
Not sure I would use it on rail stanchions.... as the potential lift force would concern me compared to a window install where that tends not to be likely.
I have used it to bed glass in hatches and the long side plastic windows on a Bayliner 2550 back in the '80's without any adverse effect... Note northern climate with freezing winters also.
ready123 wrote:Not sure I would use it on rail stanchions.... as the potential lift force would concern me compared to a window install where that tends not to be likely.
+1 wouldnt use it where and regular pressure would be applied. Just bedding glass or maybe set screws on the rub rails, but im leary about that. this stuff is very flexible though. Im just thinking on a screw or bolt insert you should be ok as a sealant.
Thanks guys! I have never used it before but I came across this article which seemed to make sense:
http://www.pbase.com/mainecruising/rebe ... are&page=1
Just thought I would see what everyone else thought of it.
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
keep in mind that the bow rails do see some force from time to time.
Could be some flexing at the base?
- ready123
Having read the article it certainly seems to me that butyl would work on deck hardware.
My only question is.... is it the butyl or the countersink that produces the good results.
I am inclined to think the countersink is also a key rather than just the butyl vs sealant change..... though butyl staying pliable for years may well deserve some consideration.
I have seen signs that my F32 windshield frame is bedded on butyl that is still pliable after 34 yrs.
- Struts and Rudders
here is what I found at work today.
http://www.google.com/products/catalog? ... JUBEPMCMAE
- lawyerdave71
