winging it here
winging it here
ok honest observation time , lets here it all , what are your thoughts of something like this mounted on an 1979 f26 ?
http://continuouswave.com/whaler/refere ... ckets.html
ok found a video of a but who tried it
http://www.youtube.com/watch?v=t0KeS5M5 ... re=related
- jon_e_quest
It's not as simple as bolting on an outboard bracket or sea drive system. The boat in the video link already had an appropriately built-up transom. If converting an inboard, you'd have to gut all the currently glassed-in transom framing and glass-in a new plywood transom core (guessing 2 1/2" minumun thickness) across the entire back of the boat, and made more difficult by the F-26's curved transom. The core would have to be built-up with several layers of 1/4" ply to successfully achieve that much curve.
As stated, a huge undertaking.
Current Boats:
1962 18' Chris Craft Cavalier
Former Trojans:
1972 F-36 Tri-Cabin
1976 F-26 Express HT
1978 F-25 Express HT
Former Trojans:
1972 F-36 Tri-Cabin
Its been done. One seller on Craigslist several years ago claimed 50+mph with and Armstrong bracket and two 200hp outboards. Boat was in the upper keys. I did see the boat but the engines had been sold.
Mike
Mike
Squall sailing dingy
18 outrage(Sold)
25 Trojan(still own, until current user finishes paying me)
Dauntless 220
18 outrage(Sold)
Dauntless 220
- jon_e_quest
I remember that Craigslist post because I poked fun at the claimed speed. There's two possibilties with respect to that boat; 1. He had a converted and rarely produced F-26 which Trojan offered with twin 4-cyl I/O's (so, reinforced transom)... or 2. He properly converted an inboard boat and it actually went 50 mph.
Given the claimed speed of the boat, I tend to believe it was not the latter. Even if you could supply enough horsepoower to routinely achieve 50 mph in a semi-displacement hulled Trojan, you'd never be able to safely control it. But then that's another topic.
Current Boats:
Former Trojans:
1972 F-36 Tri-Cabin
Former Trojans:
1972 F-36 Tri-Cabin
I didn't read the attachment, but how about glassing in aluminum framing?
well I'm leaning towards it , I called the co. today and spoke to them about building the bracket its going to be a little over 1,000.00
http://www.ebay.com/itm/Single-Outboard ... ar&vxp=mtr
My brother owns a tohatsu dealership so I should be able to snag a motor a little above cost. My only concern is that with an inboard I'm at the mercy of the engine and the only marina around here that works on them leaves me limited . however with "big brother" I know should something go wrong I have him on speed dial, coupled with the fact it is more of a money investment but should things change in the future I would sell off the trojan and swap the engine to a different boat.
this is the specs to determine the bracket size
http://www.armstrongnautical.com/brackform_new.htm
again I'd welcome all pros and cons I dont know at this point what size engine but do not need any speed as if the thing ended up a trawler it wouldnt bother me , one advantage here with this set up is we go from 120 ft depth to two feet instantly so a depth finder in this area is useless and we tend to goto alot of the sandbars here and tuck behind islands for the afternoon which I would always fear smacking the shaft and prop on but with the outboard it would in my mind be easily solved by tilting the engine up .
I've seen several bert 28's converted to outboards with great success. The carver pictured above never dropped its bow after coming to cruise speed, as far as I could tell. Weight distribution is going to be a factor.
18 outrage(Sold)
Dauntless 220
18 outrage(Sold)
Dauntless 220
